Landscape rake for 3560
Tyler88
11
New York
Hey guys, looking to add a landscape rake for my L3560. Dealers local to me only have the Landpride 1672, and was wondering if you think Id be unhappy with a 6' rather than a 7'. I need it for a job so waiting for them to get a 7' in will be an issue. Thanks!
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
240
239
Amsterdam, NY
Depends on the job and what you're doing with it.
According to Tractor Data your tractor is 59.8" wide (minimum), so a 6' rake will just barely cover the wheel tracks. If you angle the rake then your raking less than the width of the tractor. If that's important or not is up to you.
If you're raking miles of gravel road an extra 6" on each side may make for a quicker job. If your raking in VERY tight spaces (between trees for example) a 6' may be the right choice. Again, your call.
Then consider - what are you going to do with it once this "job" is done. More jobs? Personal use around your property? Etc.
If I had your tractor I would want the 7'. JMHO
Tyler88
11
New York
[/QUOTE
Thank you!
