Milwaukee Fuel Transfer Pump for Diesel?
Stitchit1
186
Cheboygan, Mi
Has anyone I ever used this pump for diesel fuel transfer? What kind of luck are you having with it? Just want to confirm before I purchase it if possible. Thank you!
9,724
That is NOT a fuel transfer pump, it's for water only, not fuels of any kind.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
I watch a few heavy service guys on YouTube. They pump diesel and hydraulic fluid with these. Seems to do good. I will say they DO NOT tolerate dirty water, our irrigation guy at work found that out.
7,107
I’ve had good luck with 2-“D” battery operated pump from Amazon for $30 +/-.
I pump both diesel and gasoline with mine.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
861
787
E.
we use this exact pump as a backup to circ. pool water through a biomass boiler in case of power failure and to prime pool pump. works great on lightly chlorinated clean swimming pool water.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,150
3,413
I saw that at one time. Since they explicitly say not for fuel......
Kinda a bummer since that would suit the rest of my cordless tool line up.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
233
250
Pennsylvania
This is what I use, rechargeable 21V battery power.#####After 4 months of use it quit....no support from CHINA manufacturer....MY bad...this is junk look elsewhere
arml
Jan 27, 2022
233
250
Pennsylvania
I’m assuming this one you are using most likely has a rubber impeller?
More nylon and replaceable paddles come with it, easy to replace, have had no failures yet. nice unit.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
With an adapter from amazon, power the pump with a 20v Dewalt battery. They make similar adapters for Milwaukee, Bosch, etc.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I have put diesel through mine. it ran fine. Lots of field tecks use them to pump fuels and oils.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
391
604
NH
Harbor Freight these as well. Less than half of Amazon price. Try them out.
