Engine Horse Power not as advertised
BillyTee
Kubota M6000 Tractor
May 8, 2025
Sanford, NC
We are finding out that the advertised horse power is not correct.
We were expecting 70 advertised horsepower from a 2022 tractor,
but tests show it only produces 46 horsepower.
Is this correct?
Advertised vs Actual?
Flintknapper
L2350DT
May 3, 2022
1,938
2,454
Deep East Texas
Well....with ZERO other information (testing and how it was done) we are left completely in the dark.
5,695
so 3 year old tractor, probably has 3,000 hrs on it, never maintained, lousy fuel , plugged filters ??
Yooper
3901 LA525
May 31, 2015
1,643
785
NE Wisconsin
Flintnapper pretty much sums it up. How was the hp measured? PTO, crankshaft, at the drawbar? What kind of dynamometer was used for measuring? Were the numbers calculated for temperature and atmospheric pressure? How many hours on the engine?
5,284
Is this correct?
Your profile lists an M6000 - is that the tractor? I can't find any Kubota with that model number. Is it perhaps an MX6000? If so Kubota claims 60 net engine HP and 52 PTO HP.
Kubota quotes both gross and net flywheel HP for their engines. What are you measuring and how?
3,452
6,633
Is this correct?
"Remember the quality of your question directly affects the quality of your answer."
lynnmor
B2601-1
May 3, 2021
1,571
1,330
Red Lion
Here is a video about recent developments in horsepower variation. While it may not exactly pertain to the OP's question it will give some information about the nonsense that is going on.
Bmyers
May 27, 2019
3,450
4,302
Southern Illinois
8,764
Is this correct?
Nowhere near enough information to even help you out!
8,810
BBFarmer
Jul 12, 2024
582
1,159
Terry, MS
Dang it Billy! Now look at what ya done did...... we got no dagnabit info :ROFLMAO:
Reckon the feller done got lost out yonder ways!! LOL
armylifer
Mar 26, 2013
2,147
920
Thurston County, WA
He spent 11 minutes on the forum and then disappeared. I hope that he comes back with more information. Maybe he got sidetracked.
RBsingl
Jul 1, 2022
485
562
Central IL
I suspect his computer power supply was not as advertised so he is unable to develop sufficient power to make another post 🤣
For a fun look at horsepower, take a look from the late 1960s into the earliest years of the 1970s when SAE starting rating HP using the engine installed in the vehicle with all standard driven accessory items, exhaust system, etc. instead of the gross HP which was the bare engine on a stand. Some manufacturers advertised dual ratings for a couple of years and car/truck engines with a gross HP in the 300+ range were making only slightly over 200 HP in operational form. For example the hottest engine in a 1971 Corvette was a 454 rated at 425 HP however the SAE net rating was 325 HP while the base 350 CID engine was 270 gross/210 net.
The electronics industry was even worse with the low end manufacturers rating their audio gear using the IPP (instantaneous peak power) method. Basically output was measured with a scope with the preamp gain set to max and a transient event was created (typically dropping the tonearm on a record). The scope captured the peak which sometimes was the last sound that particular unit ever made. It wildly overstated the practical audio output capability which was often around 1/10th of IPP power.
Rodger
BillyTee
May 8, 2025
Sanford, NC
Is this correct?
So….lets see if I can do a better job…..on my question!
checking used Kubotas both equipped AC cabs.
2019 M4-071Delux has a PTO HP advertised and operater manual documented at 60.
535hours on this tract dashboard.
2021 M6000-HST has a PTO HP documented at 51.8.
237hours on dashboard.
Apparently when the M4-071 was tested using a water dyno tester at the PTO shaft it only produced 46HP at maximum rpm.
So….what is the true PTO horsepower???
Is it worth while to do a dyno test before a used tractor purchase?
Hopefully I asked my question correctly.
3,248
1,870
At 500 hrs you'd expect it to be just broke in, wouldn't you? How does it run? Could be something as simple as a dirty air filter.
* What was the condition of the dyno? Was it calibrated and properly operated?
* What altitude and ambient temperature were the tests run at?
* Was the tractor properly warmed before the test?
