BX-tractor shift fork failure
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
My 2021 BX2380 has just developed a problem where it is stuck in the high range. The shift lever moves fine across the entire range, but the tractor remains in high gear. Took the tractor to a dealer. The service department said that it is likely the shift fork has failed. They are quoting a repair of about $4K. This is a bit unexpected since the tractor barely got 200 hours on it, and I cannot think of anything other than bad metallurgy that could have caused it. It always shifted with a bit of resistance or hesitation but then it "snapped" to where it simply moves back and forth with almost no effort. I am thinking of leaving it as is since I mainly use it for mowing and front end loader work. However, the dealer indicated that if I leave it this way, the transmission may disintegrate because of the broken fork pieces in the case. Apparently there was a TSB on a broken shift fork but my tractor is not in the specified range.
What do you think I should do?
  • Sad
MOOTS
MX6000
Jun 27, 2019
2,202
2,769
Canton, Georgia
Not doubting your dealer, but I’d check that roll pin #80 is there.
Fedup
343
136
Winchester
If you can shift the lever and feel the detents, then a broken shift fork is a definite possibility. On the other hand, the roll pin mentioned is much more likely to break than is the shift fork.
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Hmm, good question. I am going to call them tomorrow and inquire. They were pretty confident it was something inside
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
Well, a roll pin is way cheaper than a HST rebuild, trust me I've been there. Hope the best for you.
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
258
169
WNY
I would think a 2021 would still be under power train warranty?
Orange man
Jul 23, 2014
258
169
WNY
The powertrain warranty is for 6 years
Orange man
Jul 23, 2014
258
169
WNY
No, I just traded in a 2021 and the warranty book says 6 year or 2000 hours
Orange man
Jul 23, 2014
258
169
WNY
Find a new dealer then, or call Kubota
Orange man
Jul 23, 2014
258
169
WNY
I am not sure why they are "seeing" anything? You can call Kubota and they will tell you how much time is left on the warranty
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Here is the quote
CAUSE
Tech verified customer concern.
- Tech states range shifter moves but does not shift internally.
- Tech verified that the selector lever moves the shift rod but does not
actually shift.
- Tech states this failure has occurred internally of the transmission.
- Tech states to provide a full estimate the loader, backhoe, rops, rear
fenders, seat, fuel tank, and transmission / HST assy must be removed.
- Tech states the Transmission / HST assy must be torn down to identify
failure.
- Tech states a full estimate of full parts needed will be provided after
tear down.
LABOR SHOP
** TOTAL LABOR SHOP 166.60
SHOP LABOR MISC
00000 11.7 HRS OF SHOP LABOR 2000.00
BX23S-1
560
220
No where Special
Here is the quote
CAUSE
actually shift.
failure.
tear down.
LABOR SHOP
SHOP LABOR MISC
So when you called the factory, about the warranty, what did they tell you ?
jaxs
B1750HST
Jun 22, 2023
1,026
791
You should go to dealer and examine roll pin 80.
If pin is broken, show manager the pin then INSIST he put what he saw (broken pin) in writing. Then load tractor and take it home. I wouldn't allow them to touch my tractor again even if it was free.
If pin is not broken I would take tractor home and pursue truth on powertrain warranty. If warranty has expired I would shop around for repair proposals.
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Well, the tractor was purchased on a company account and therefore it was a "commercial purchase". Apparently, it is not the same warranty
  • Sad
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Good advice but I told them to go ahead. I am new to this area and really don;t know anyone around here who is knowledgeable to do this kind of repair. I recently had issues with a kubota engine in another piece of equipment and had to do work myself because kubota dealer would not touch it and the nearest dealer with engine expertise was in dallas
  • Sad
