Chainsaw Mount
5,404
5 bolts.
Also incorporates skid plates for hydraulic lines.
Welded a similar square tube to the B26. Handy to carry chain, saw, long handle tools.
Looks very handy for sure.
I'm gonna do something similar on my L
Thanks for posting the pics.
Showmedata
LX3310
May 18, 2022
210
202
Boulder CO
I made one similar in shape to the Sawhaul, because I always try to build rather than buy (too Scotch, as my mother always said about herself). I mounted it to the loader mount using existing holes, but after a while I found that sorta in the way getting in and out of the cockpit so I moved the scabbard to my chipper. The saw and chipper are 99% of the time used together, so it's a perfect pairing. And it's lower to the ground thus easier to get the saw in and out. Next I just need a decent rack on the chipper for the fuel & bar oil jugs.
johnjk
Apr 13, 2017
1,803
2,189
West Mansfield, OH
You guys are inspiring me. I have an old hitch basket I no longer use. Time to repurpose as a carry all basket
soloz2
85
80
WNY
Almost forgot about this thread. I made this not long ago. Just some scrap angle iron and a cutting board. I originally mounted it on the loader, but after painting the bracket I moved it to the ballast box and just bolted it on.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
'Bannon' chainsaw holder will handle a pretty good sized saw. I usually just throw my small 'limbing' saw in the basket, but sometimes put it in the bannon.
But it will handle a larger saw just fine too. Below is an ECHO CS-680 with a 24" bar (their second largest Pro-Saw), so its not little.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Like the extra carrying capacity. Chainsaw use often requires other tools. Have a basket like that on the four wheeler.
Is there enough room to clamp the bar with a plastic sheath? Give you and the saw a little protection.
5,404
I like the concept, but there is no way that I would last more than 20 minutes without snagging my, arm or hand, on that chain. 😩
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
Yes, the plastic sheath will easily fit into the opening. The fixture will open up to about 1.5" wide to accept the bar and sheath.
