I know!!! Another boring fuel filter MOD – TWF!!! But I’m posting it anyways. LOL
I’m on a tight budget and couldn’t talk myself into pulling the trigger on buying a $40 - $70 fuel filter from a bigger tractor model as others on OTT have done (and quite well I must say).
So I thought what the hey, Kubota puts faith in their cheap little filters so why not try using what I have but make it better. So I relocated the OEM filter from under the tractor to the front and made a little aluminum bracket to attach to where the 2nd filter is already mounted. Also used the same filter holder/bracket the original primary filter had to mount to the new aluminum bracket.
What a PITA (as everyone knows) getting to the first filter underneath. I was worried about clearance with the hood but it fits great, plenty of room. Third picture is with the hood closed.
Half a bag of zip ties and no leaks. BAZINGA!!!
5/16" ID Fuel Line Hose SAE 30R7, 150 psi 10' $12.00
Stainless Steel 5/16" Mini Ball Valve Shut Off Valve 5/16" Hose Barb $ 8.50
Brass Barb Union Hose Fittings, 5/16” to 5/16” with Hose Clamps $ 5.25
Homemade Bracket Free
Total $25.75
Total $25.75
