Quick hitch options
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Also,
Being somewhat new to using implements with my tractor(s), I have recently purchased a quich attach QH05 and want to use it with a LandPride RCR1242 with my BX1880 mostly for clearing small hedge type brush on my yard. Do I need a "floating top link" in addition to the quick hitch to use with this setup, and the same question if using my BX23S? Thank you to all in advance!
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
Page 20 of the RCR1242 manual shows a floating top link already on the unit. The QH would need to be adjusted so the top clevis pin is vertically over the lower pins to keep the deck level.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Thank you for your reply, my friend! I am somewhat confused though, seeing that the QH05 model quick hitch has a "fixed" top connection that doesn't allow for the adjustment that it looks like called for in the diagram. Now, grant you, I have not tried to hook this up as of yet to the bush hog, but to another implement that is much older and just may not have been compatible at all. I noticed on the LP cutter the "quick attach" logo, and of course the quick hitch itself is for this specific implement. I just wanted to confirm with a very knowledgable group on the subject before that I proceeded to connect the two pieces of equipment to be safe. Again, I greatly do appreciate your sharing of the info!
5,210
Well Digger, welcome to a large Orange dysfunctional family :) Odds are if somebody in here cant come up with the answer, you dont have a problem ;)
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
You may be just like me, I'm a visual learner and need lots of pictures. LOL!
The circle on all the pictures is where the top hook on the QH10 fits on the upper clevis pin of the RCR1242.
The arrows show the floating top link already on the RCR1242.
Put your QH10 on the tractor, back up to the RCR1242 and hooker up. The width of the QH must fit the lower pins on the mower. You may have to raise or lower the top hook on the QH to line up with the upper clevis on the mower.
Screw the top link adjustment on the tractor in or out to get the upper clevis pin to line up with the lower hitch pins. Follow the instructions in the link I gave to adjust the cutting height.
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
Sorry should have included this one also.
Arrow is pointing at the tractor's top top link you turn to adjust the Top of the QH in or out.
Follow the instructions in the manual.
10,676
A QH 05 and QH 10 will not work for that Mower, you need a QH15 or better yet QH16.
Or save a ton and get one off ebay or harbor freight with a removable top hook.
And moving this thread as you do not have a grey market tractor.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
This is what I had to have for my quick hitch and fdr1672
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Thank you to everyone for your replies, (especially the photos, "Bee-Positive") again, I am new here and to the tractor scene. Please forgive if I posted in the wrong section, I didn't understand what the "grey market tractor" meant. I have the QH05 quick hitch and does not have the top link adjustment capability as the QH15 has, probably should have bought it instead, I guess. Live an learn= expensively$$$. Dang.
2,929
As to what the grey market section is =
At one time people were importing Kubota tractors into the USA from Japan. Those tractors were Japanese domestic tractors that were not intended for the USA market.
Then Kubota corporation became a bigger presence in the USA and since Kubota did not move those tractors into the USA they do NOT support them. In fact, a Kubota dealership would loose there franchise if the service or sell parts for a grey market tractor. They probably often sell parts to grey market tractor owners but they are selling parts for a similar valid USA model and are unaware that the buyer is really maintaining a grey market tractor owners.
You have a valid model for the USA so don’t need to worry about that.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Wow! That is some interesting information. Had no idea. Thank you for enlighting me on this.
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
Once again NIW picks up what I obviously missed, even a couple of my photos show the fixed (welded) non-adjustable top hooks of the QH05 and QH10.
Sorry about that. Sometimes I'm as sharp as a butter knife.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Please elaborate on what you mean by "it won't work on that tractor", because I have hooked it up to the tractor just fine, but not to any impliments as of yet? Thank you in advance for your reply, my friend.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Me too, some times, my friend. No worries. Thank you again for your replies. Offering help is always a blessing!
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
He said that QH won't work on that MOWER. As you say it mounts to the tractor just fine.
Whenever you buy a QH you must make sure the distance between the lower arms of the hitch will fit the pin width of the attachment(s) you're try to hook up. Some low priced QH's on Amazon are too narrow. Sometimes you can reverse the pins on the attachment, point them in instead of out, to compensate, but it's better to get the right QH. Be aware of the size of the pins that come on the attachment, Cat I, Cat II, or Cat III. Cat I pins are the smallest diameter. Attachments for your tractor should come with Cat I or Cat II pins. Cat III pins are for large equipment. Most QH's have Cat II slots. If your attachment has Cat I pins and your QH has Cat II slots you can get bushings to make it fit correctly, or replace the CAT I pins with Cat II pins on the attachment. The less slop the better.
You must also be sure the height from the lower pins to the top where the hook (clevis) connects is also correct. Most QH have adjustable top hooks that can be moved up and down in a series of holes, or removed altogether, to accommodate different attachments. The top hook on your QH is fixed in one spot and limits the type of attachments you might be able to connect. One more thing, on my Harbor Freight QH the top hook didn't stick out far enough to hook up so I had to buy another hook that did to make it work.
Simple - right!
Some just buy a set of Pat's Quick Hitch, they are highly recommended by those that have them and are another option.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Simple - right!
I may not be following what you guys mean, but the "Quick Hitch" is by Land Pride, and it is said to work with the Land Pride bush hog that I have also purchased, along with a 5' blade by the same. If it fits on the tractor, and the attachments are by the same brand and are said to work with this model "QH05", why will they not work with my tractor? I am so confused guys, sorry.
10,676
Sorry I was going off of Old info, bad wolfman! :cry:
Yes that mower does NOT take the added swing bracket and is set up for the lower setting on the QH hook (which is where the fixed hook setting is set).
So it should work with all the QH's available.
DiggerDug2023
BX23S, BX1880
May 6, 2025
12
Georgia
Thank you for clarifying this for me, Wolfman! No worries buddy, the "QH" stuff is obviously confusing with the aftermarket stuff out there. Thank you again for your assistance with my question(s).
Bee-Positive
Nov 16, 2022
824
815
Amsterdam, NY
After all that - now get out there, hook it up, and post a picture!
We love pictures.
