L3400 positive battery cable
BuddyG
L3400
May 6, 2025
Anyone have a workaround for replacing the positive battery post connection without buying the $80 positive cable assembly?
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
259
144
Agua Dulce, California
those are good alternatives and will work, I should add that I take the old cable and use my hydraulic crimp tool to put a good lug on the old cable with marine grade shrink tube. redid all the cables on my 2500 Dodge ram diesels batteries. and used the military grade hummer terminals. just to add to the story.
Sawdust&Shavings
Apr 25, 2023
210
252
Stafford, VA
I usually go here:
11,010
That cable is not a normal cable as it has a second lead connection.
If your not wanting to alter the tractor wiring you need to get a stock cable.
If you alter the stock wiring you could then use a generic cable.
It's a $66 not $80.
