BX23D with Starter Relay No Crank Issues
rgarraton
BX23D
May 5, 2025
Upper Marlboro, MD
I have been going crazy this past week trying to figure out what's going on with my 2005 BX23D. I had no start issues a few years back and installed a starter relay, which solved my problems. But they've since returned. Just prior to going out this time, I had to press my pedal (forward and reverse) to get it to crank over. I stepped off of the tractor and it shut off. I have not been able to get it going since. I've replaced the seat safety switch, which was broken, but bypassed. I know it cranks because I can crank the starter directly or by passing the neutral safety switch. By the way, when I bypass the neutral safety switch, the tractor starts the moment I turn the key to warm the glow plug. While it runs, the engine revs high and the starter solenoid is still engaged on the flywheel. I installed a new neutral safety switch, and it still didn't crank. I replaced the 12 year old battery, and nothing. I checked the fuses, and nothing was blown. All other safety switches are engaged or otherwise working. What am I missing? Thank you in advance for your help.
3,185
1,795
Sounds like multiple problems
* Having to move the pedal to start sounds like the linkage needs lubricating, adjusting, or a bad switch
* Starting in the preheat position sounds like a bad key switch
* Shutting off when you dismount sounds like a neutral switch bad or maladjusted.
* Shutting off when you dismount sounds like the seat switch is functional, but you say it is bypassed?
I don't have access to the WSM for your model, do you? I understand some models have a diode. If yours has one, I'd check it.
rgarraton
BX23D
May 5, 2025
Upper Marlboro, MD
I lubricated the pedal and checked the adjustment of the neutral safety switch. I did replace the seat safety switch with a new one and removed the bypass. I will have to try the key switch. Is there a way to check the switch with a voltmeter before I buy a new one?
3,185
1,795
Yes, but the diagram in the WSM Electrical section would sure help.
rgarraton
BX23D
May 5, 2025
Upper Marlboro, MD
I found it! It was the PTO Clutch Lever that was not making contact with the safety switch!
