Cement Mixer....Can I add this?
DrakeRemoray
L2350DT
Jun 24, 2024
71
24
Alvarado TX
Can I add the following to my Kubota L2350DT? Horsepower is within specs. I am specifically looking at the Hydraulic setup and how it would be hooked up? I have a front end loader hooked up and just need to know if I need to add another remote hydraulic to run this...and if so, which one would work?
11,248
Yep you shouldn't have a problem running it.
You will need to make a loop off of they hydraulic system to a spool valve (hydraulic valve) to run the top cylinder.
I would suggest you add a two spool valve, as they are close in price and gives you options down the road.
7,344
7,344
Post a picture of the loader outlet block under the front seat.
