Thoughts or advise
Plant 175
Kubota Sidekick and B2601
Jun 3, 2021
135
67
Wisconsin
Well boys and girls I got my flail mower hooked up last month and started to cut my switchgrass and then all of a sudden the 2601 totally shut off. I jumped off and looked and could not believe the bone headed mistake I made. I ran over some woven wire fencing I took off a fruit tree a year ago and forgot to pick it up and the switch grass grew through it and camouflage it.
I cut the part outside the mower off but it is wound around the inside of the mower. I have not used the tractor since but Tuesday is the day to untangle this mess. I guess put some blocks under the mower and crawl under it and start cutting the wire out small piece by small piece. I’m going to use a wire cutter. Here is a pic of my mess. Any thoughts would be appreciated.
10,744
Your in for a lot of work!
Cut off wheel on a grinder?
Maybe Plasma cutter? ;)
ruger1980
L4310 w/La682, L225
Oct 25, 2020
569
247
CNY
Invest in a heavy set of diagonal cutters with long handles for plenty of leverage and reach.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I chopped up a box spring hidden in some tall grass the very first time I used my RCD 1884 rotary cutter. Good times!
bird dogger
Vendor Member
Feb 24, 2019
1,782
1,758
North Dakota
Been in the same predicament with my rototiller while locating old buried barbed wire fencline! I agree with NIW..... thin cut off wheel got the majority off quick and easily. For the rest (sorry I don't have a pic of it) a stout wire hook on the end of a handle works well to pull loose the tightly entwined pieces.
Work smart and look for and undo the outer layers while working your way inward.
2,957
I suggest you get the mower as high as possible and set it on some wood cribbing so it is at a comfortable work height. Then detach it from the tractor and roll it so it is easier to see the wires. Strap is to something so it doesn’t want to fall onto you.
Depending on how hard it is to remove the blades it might be worth the effort to remove some or all of the blades so you don’t have to worry about cutting your hands on them.
Then go to a fence supply or a tool store and get a set ok Knipex wire cutters for heavy wire. They may actually be small bolt cutters but they have compound leverage and can cut heavy wire much easier than normal cutting pliers.
I would try to cut it in several places around the mower “axle” so you are not having to pull it out very hard.
Good luck and be safe!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,900
2,317
Western MT
I'd consider taking the stump jumper and blades off. It might be a bit difficult, but faster than cutting it off by the piece.
If you are talking midpoint mower, I'd take it off, flip it over and still take everything off. I've lifted my mower deck for my lawn mower and used the tractor to provide more access. Not "easy", but easier than laying on the ground to reach parts.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
I feel your pain! Not wire, but a big bunch of 'hay string' (not seen in the grass until too late).
6,252
Agree with 'take it off and get it up high and safe ! 'book' yourself ALL day to do the job, use whatever 'cutters' you have, piece by piece by piece by.....
At least it's probably warm and sunny where you are......
Worst one I saw was a 'forest mulcher' that found a very ,very long section of razor wire(barbed wire). That guy was NOT happy....
ken erickson
Nov 21, 2010
1,394
2,567
Waupaca Wisconsin
I recently removed fencing wire from the drum of a forestry head.
We discussed a angle grinder, which would have worked well but the location and time of year was not conducive to throwing lots of sparks. Last thing I needed was to deal with a wildfire or a burned up track loader.
The wire was too large in diameter to use a heavy duty side cutters, at least in my hands. I picked up a 14 inch bolt cutters which worked well. There was enough compound leverage that I could snip the wire right at the tip or anywhere else along the cutting edges.
I can say I was able to clip wires that was wound super tight right up against the drum without leaving a mark. I do not think that would have been possible or time efficient with the angle grinder and cut off wheel.
7,543
Jimh406, flail has no stump jumper! ;)
4,065
I think Russell has found a sneaky way to tell us he’s BTDT. 🤣
NorthwoodsLife
Oct 15, 2021
1,410
1,472
Wisconsin
That is never good. Use cutters.
I have found similar when rototilling customers properties years ago. Chain link fencing, chicken wire, bailing wire, conduit and even a 20' piece of romex. The romex zipped through the weeds like a fast moving snake as it coiled up in the tiller. Scared the snot out of me.
The good news is I had (learned) a real good understanding of rototiller disassembly. I knew that tiller very well.
Good luck and somehow make it fun.
NorthwoodsLife
Oct 15, 2021
1,410
1,472
Wisconsin
I would take it off off the 3 pnt and flip it upside down, carefully. If that won't damage the top.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
I don't have a PTO driven mower, but I have found some long-lost wire, rope, and old garden hose over the years with my belly mower. Do you have a fel on your machine? If so, drop the mower, and hook onto it and hoist it vertical. Standing in front of it is a lot easier and safer than laying under something that could give way and fall on ya. Besides you can see better than laying on your back. Just a thought.
Plant 175
Jun 3, 2021
135
67
Wisconsin
Thanks guys for commiserating with me I guess it’s a club that only distinguished people get into🤔🙄. I have the cutters and a grinding wheel which someone recommended and will go to battle 🤞💪
Elliott in GA
Mar 10, 2021
861
863
North Georgia
Obviously, wear gloves. These are the best that I have found to prevent punctures and cuts with good dexterity and not hot:
$35 at Amazon. I recently wrestled 20-30 feet of barbwire out of very heavy brush without any injuries, despite often grabbing the barbs and pulling with body weight.
HappyTopster
In the hunt for tractor; Have Honda Pioneer 700, 5x8 trailer, XMark Radius E
Apr 27, 2025
59
30
West of Asheville
Excellent advice!
3,491
I feel your pain.
I was driving one of my LandCruisers thru some tall grass when it stopped abruptly and died.
Turns out I had run over an old single box spring which wound around the rear driveshaft as tight as a drumhead.
Being a spring, it was hardened wire, and a bitch to cut.
Took hours laying on my back in 110° heat with a pair of bolt cutters that thankfully, I had in the tool box.
I do not care to repeat that episode.
7,543
I've gotten into some wire a couple of times with a flail mower, but it was single wire (like an electric fence). It was heavy wire. I removed the PTO shaft, raise the mower, put cribbing under it for safety. I was able to reverse the drum which made it much easier to remove. A lot of it actually just un-wound.
