Looking for an electrical connector on G1800
Roger Fowler
G1800 lawn tractor
Apr 20, 2025
Apex NC
Currently the seat switch is not working. The switch checks out fine so I am looking for the 3x2 connector which mates the switch, fuel pump and sensor, etc. into the rest of the wire harness. Anyone know where it is located? I'm trying not to tear the tractor apart looking for it :).
Thanks in advance. (Slowly working the bugs out.......
TJP440
Gr2120 and B3200
Apr 16, 2017
65
34
Omaha, Ne
What are your symptoms? Might be one of the other interlocks? I'm not overly familiar with the 1800's but know other models have interlock /switches that can cause no start /run issues 🍻
6,876
For what it's worth, a long while ago my seat switch tested fine, but was causing problems.
Turns out the seat switch wasn't fully closing when I sat in the seat to allow operation.
There's many variations of seat switches across models.
Not familiar with a G1800 but might be a good place to start.
Roger Fowler
G1800 lawn tractor
Apr 20, 2025
Apex NC
Well this was an easy one to resolve. :):) I decided to go check all the safety systems per the Kubota manual. PTO switch was not inhibiting starting when the PTO was engaged. The switch had sat in the NC position so long it was stuck. A little exercising and now it works. And now the seat switch works too!
Thanks for the responses.
Roger
