Air in my hydraulic lines after replacing 3 hoses.
2,597
Run tractor then use the levers to move the backhoe around and the cylinders and hoses will fill with fluid. Just extend and retract the cylinders a few times and the air will be expelled back into the sump.
nezmun
L2350 Kubota Tractor
Aug 13, 2024
20
Washington State
Thank you I'll try that tomorrow and let you the results.
nezmun
Aug 13, 2024
20
Washington State
Thank you for your help. I got the air out and found I had two hoses hooked in the wrong place. Thanks again.
BAP
Dec 31, 2012
3,088
1,224
Don’t forget to check your hydraulic oil level after you get the air worked out of the hoses. Most likely you will need to add some.
