Overfilled engine oil on BX23
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
171
79
Danville
Looks like I may have about half a quart extra oil in the BX23. Should I be worried? How much overfull is too much overfull?
3,057
Overfilled can be worse than underfilled!
Over full is BAD simply because the moving parts will whip the oil - and place a zillion air bubbles in it! And we all know air is not a good lubricate!
Get under and pull plug and remove a good bit - more than you need, tighten plug and if you wish - add the oil back to the upper mark.
Now IF you have a large syringe laying around and some small tubing - you can suck out a bit via the dipstick passage. Most of us are forced to do this on water craft since the plug would make a hellva mess in the boat.
pjoh784350
May 3, 2019
171
79
Danville
THanks..
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
471
268
Randolph county N.C.
I would remove oil filter, drain then re-install. Run engine, check oil level, repeat if needed until correct oil level is reached.
pjoh784350
May 3, 2019
171
79
Danville
Thanks to all for the feedback. Dropped the belly pan and drained out excess. As an FYI, I tried to buy a fuel transfer set up relatively cheaply to drain through the dipstick tube to no avail. I had hoped to avoid removing the plug again as the ground to upright effort is getting harder and harder!
3,075
I don’t know what your level is for relatively cheap but these Mighty Vac systems would be able to suck up the oil through the dipstick tube.
There are actual vacuum systems for oil changes through the dipstick but I think they are more expensive but also more useful.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,299
817
under a rock
I've got the 2+ gallon Mityvac fluid extractor...... comes in handy.
would work great for this situation..... comes with an assortment of hose sizes and adapters for dipsticks and the like.
