Grapple for loader removal?
JJMJ
M7060HD, LA1154, SGC1572 & etc.
Apr 30, 2025
Florida
I have the LA1154 loader on my new M7060HD but foresee using the tractor a lot without the loader attached.
I do not have a need for a bucket, as my son has one to use around here with his M6 and track loader.
On order is the SGC1572 grapple, and I would like an experienced opinion / advice on whether the grapple is a practical alternative to a bucket for removing the loader from the 7060.
Thanks very much
11,691
Thanks very much
Welcome and congratulations on a great tractor!
I have an M6060 with the LA1154 loader, and the loader has been off the tractor 95% of the time over the past three years. I just put it back on a couple of weeks ago but will be taking it off for a discing job this weekend. I run front weights when the loader is off and will be putting them back on in a couple of days. I ordered a piece of 5/8" thick plate that I'll weld to the front brush guard so that I can have the front weight bracket on the tractor along with the brush guard.
If I understand your question correctly, you're asking if you can use the grapple when it's on the ground to manipulate the loader arms to align to the tractor. If that's your question then the answer is absolutely yes. I left the loader off the M6060 for months with it supported by the grapple and stand. It was/is no trouble to remove or install.
Here's my LA1154 with EA grapple hanging out with some elk.
JJMJ
Apr 30, 2025
Florida
Yes, but its ability to lift the tractor's front wheels off the ground for changing it out is my main concern.
Is your grapple shaped similar to this, what EA calls a Root Rake Grapple, or is it what they call a Root Grapple with more of an extended bucket-type profile?
Do you think it would make any difference?
11,691
For changing it out? Changing what out? Changing out the front wheels/tires?
I have an EA Wicked 60 root rake grapple.
JJMJ
Apr 30, 2025
Florida
Sorry, I probably misinterpreted the loader manual's instructions for removing (changing out) the loader from the tractor.
It says to "lift the weight off the front wheels with the bucket".
That doesn't necessarily mean to lift them off the ground, does it?
I never took the loader off my dad's Massey Ferguson 481, so... not experienced.
And I've already told my son, who is experienced with buckets, to stand by for my first attempt.
Your grapple has the same profile as mine will have, so I'm confident now that it doesn't have to be a bucket.
Thanks so much.
11,691
Thanks so much.
The loader has a stand that swings down. You simply tilt the bucket or grapple to pivot the loader about the stand and to adjust the position of the connection points at the tractor end of the loader. You don't take any weight off the front wheels.
1. Raise the loader
2. Lower the stand
3. Lower the loader so that the stand is on the ground
4. Tilt the bucket or grapple to take the weight off the pins where the loader connects to the tractor
5. Remove the pins
6. Back up a few inches until the loader arms are clear of the connection points on the tractor
7. Shut off tractor and disconnect the four hose connections and two 3rd function hoses if present
8. Start tractor and back away
11,691
@JJMJ, I removed the loader from the M6060 this morning and it reminded me of something.
It's worth taking a few extra minutes to make sure that the left and right sides of the bucket or grapple contact the ground at the same time as you lower the loader. I had to double up some 2"x6" pieces of wood on one side of the bucket so that the loader remained level with the tractor. If your implement makes contact with the ground on one side before the other it means that your loader won't be in the same plane as the wheels of the tractor and that will make removing and installing way more difficult.
JJMJ
Apr 30, 2025
Florida
My grapple was finally delivered yesterday, and this morning I came back to this thread to review the step-by-step process that you so kindly provided.
It was only then that I saw this additional advice. Don't know how I missed a notification of your post.
Please accept a belated thanks for responding to my inquiry so generously.
5,178
Just remember,, if ya aint got any bent tines you aint using it
JJMJ
Apr 30, 2025
Florida
Got ya.
A couple of large oaks down here along with the ever-present limbs on the ground, whether by weather or those I intend to cut - so I can drive my tractor thru there!
Anticipate getting into the dirt, too. Underbrush, etc. The odd cooperative stump?
With respect, I'd like to add to your loader changeout process above a crucial Step 5b, I discovered today.
5b. Slowly roll back the grapple, and the rear of the loader will lift out of the receivers of the main frame.
Again, much appreciated.
