Backhoe Hydraulic Line Failure
rwann
MX5400
Apr 28, 2025
western PA
I purchased an MX5400 earlier this year with a BH92 Backhoe and Hyd. Thumb all factory installed. I have appx. 40 hrs on the tractor and just recently used the backhoe. I have 5 or 6 hours on the backhoe and a hose started leaking. I looked and the other hose in scarred badly ready for failure. My assumption is that the hose rubbed the side of the arm and scarred. Not sure why the leak unless it kinked. I am concerned that these should have a sheath around these hoses to protect from rubbing the frame. Any suggestions on this, past experience, etc.
old and tired
1,919
1,297
I would be talking to the dealer... let them figure out why and how to fix it under warranty.
ken erickson
Nov 21, 2010
1,408
2,628
Waupaca Wisconsin
I am sure others will weigh in but I think the main issue is the dipper stick hose routing. Not sure why they were installed with the hoses set off hard to the one side.
I pulled a quick picture off the internet that makes a lot more sense as to the routing. I would guess that in normal operation the hoses never contact the sides of the dipper stick or boom, which in your case is surely what caused the abrasion and failure. Ignore where the hand and finger is pointing, as I mentioned I just pulled this picture from the "net".
ken erickson
Nov 21, 2010
1,408
2,628
Waupaca Wisconsin
I think this picture shows the dipper stick, bucket hose placement/routing better.
rwann
MX5400
Apr 28, 2025
western PA
I have requested a sleeve. They don't want to include it since it wasn't included in the initial order. Not a problem, I told them to include it and charge me for it.
I see your point on the routing. It appears the lines may be too long or for whatever reason they are pulling out to the side and should not be. I haven't confirmed but there could be a sharp edge on the frame as well.
Thanks for the input.
#40Fan
595
431
To me, it looks like the line got twisted when it was tightened.
It doesn't help that they use the cheapest hose they can find.
HappyTopster
In the hunt for tractor; Have Honda Pioneer 700, 5x8 trailer, XMark Radius E
Apr 27, 2025
59
30
West of Asheville
They do look too long compared to the other picture. The least the dealer could do is fix it and put a sleeve on for your trouble. I’d re-visit a nd mention the thousands of followers you have on a Kubota Forum💪
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
330
315
catlettsburg, ky
That looks like a rubber hose.
Is there a hydraulic thumb on your backhoe?
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
604
617
Lake Almanor, Ca
I rigged this up 15 or so years ago…haven’t ever had any problems or issues. When I did it I figured I would snag a line, scuff one up or somehow screw up one of them. Nope…it gets used a lot too. IMG_0432.jpeg IMG_1417.jpeg
