B3350 Diagnostic Port Location?
Rob.Cox.Kubota
B3350
Apr 26, 2025
Cornwall
I have a 2018 B3350 and I cannot find the Diagnostic Port location.
I have looked everywhere and followed the wiring harness several times.
Can someone please help!!
Rob.Cox.Kubota
B3350
Apr 26, 2025
Cornwall
Thank you for the reply.
I would like to purchase Diagmaster to troubleshoot error codes. From what I can find, Kubota uses a 4-pin diagnostic connector (lots of companies sell a Diagmaster equivalent).
I can neither locate a 4-pin diagnostic connector on my tractor, or any diagnostic equipment that connects directly to the ECU.
The aforementioned thread states, " Any download to update it is done through the diagnostic port by the dealer. The port is located under the seat on Cabin models and on the LH side of the engine, right above the ID tag on the ROPS models. " I have the ROPS model and ID tag on the tractor frame is on the left-hand side beside the battery (no 4 pin connector).
Do you happen to know exactly where the 4 Pin diagnostic connector is located (if it exists) or how the dealer would connect to the ECU.
7,187
Shucks - - thought I found something helpful, but it's L series and photo is a "Generic" picture.
Does 2015 Kubota l series have diagnostic port? | OrangeTractorTalks - Everything Kubota
Found ECU reference in Kubota Tractor Corporation - Illustrated Parts List
Hard to get a reference as to its location. That's for a ROPS tractor.
Is this a cab or ROPS model?
I've gotten so I'm squeamish dealing with electrical/control systems. Too many possibilities of things going awry. Don't even like to change batteries on ECU/ECM equipment anymore. Heard too many horror stories.
Rob.Cox.Kubota
B3350
Apr 26, 2025
Cornwall
****Thank you for the reply****
I have the ROPS model. The ECU (pictured in the supplied illustrated parts list) Is located under the dashboard. However, but i cannot locate a 4-pin diagnostic connector anywhere near it.
