Bucket cutting edge
Ryeder
B2650 hsd
Feb 10, 2022
15
NH
Good day. I'm replacing the bucket cutting edge on the Kubota and it looks like it's going to be a pain. Any suggestions on how to make the replacement a bit easier? Or, at least more labor efficient?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
There are lots of options. Whether you're starting with a weld-on or bolt-on, if you want something aggressive like Piranha or smooth, toothed, etc. I've made a couple of smooth edges and one toothbar. With the current state of my property and the potential tasks a smooth edge will do everything. If cleaning the fence row ever rises to the top of the list of things to do, maybe something like the Piranha will be the best option.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
It's just a 'pain'. Not really any way around it.
IF your bucket edge (now) is not straight, then fitment becomes an issue.
As mentioned above, best advice is to take it to a welding shop and let them do it.
Missouribound
Jun 17, 2014
668
62
Missouri
Piranha also has a smooth edge bar that attaches the same way.
2 bolts, off or on.
11,757
I have bolt on cutting edges on both buckets. The factory bolt on cutting edge was originally on the MX bucket but I swapped it out for a wicked tooth bar from Everything Attachements. The M6060 bucket didn't have a bolt on edge so I drilled 11 holes in the bucket and mounted the factory edge on that bucket.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
84
Waterford, Maine
My vote is for the Piranha. I have the straight and the cutting bar. Once you drill two holes for one, it immediately fits the other. You can remove one and replace the other in two minutes. Simple as pie.
SFB
MX 5800, Sidekick
Apr 25, 2023
Darby, MT
EA's Wicked Tooth Bar installed on my MX5800. Regardless of what you put on your bucket, do it soon before there's any damage to the bucket edge. It's much harder to install a cutting edge on a bent bucket.
drygulch
L3901, LA525, ever changing attachments
May 30, 2024
201
256
Alabama Foothills
www.ebay.com
Depends on your needs, but I second on the bolt-on tooth bar. My Piranha was fantastic ROI for me.
Love the added grip when lifting or dragging logs etc. and makes digging up creek rocks, or dirt for that matter, so much easier. A must have, IMO.
Good luck,
Greg
Bee-Positive
Nov 16, 2022
1,150
1,067
Amsterdam, NY
Another vote for the Piranha bolt-on tooth bar. You are in NH - you have rocks, no doubt about it. Getting one will make you a believer after the first use. It also adds support to the buck edge which has to help from bending it. I take mine off to do "soft" work like back dragging, in the garden or move snow banks, etc.
