BX2380 No Brakes
stevewayne
BX2380
Apr 24, 2025
I have a BX2380 with 440 hours on it. I was using the tractor carrying some wood over the hill in the front bucket and barely had any brakes at all. Now I have no brakes at all. I adjusted the turnbuckle but I have zero resistance on the pedal. The linkage is pulling forward when stepping on the brake. I have a feeling I know the answer to my issue, but I’m hoping someone has better news for me and it’s something I’m just missing. Thanks!
7,349
I seldom use brakes, do you?
Had my tractor for 12 years….
Not being a smart aleck, just curious.
stevewayne
BX2380
Apr 24, 2025
I tend to use a combination of the hydro and the brake if going down hill with a load, just a habit I guess
7,349
That could be your issue.
I literally have (almost) never used the brake while driving. I traverse some steep slopes.
I occasionally use the parking brake if I stop/park the tractor on a hill.
Low range is good for the hills.
Always keep the tractor in 4WD while on hills, and/or carrying weight in the loader.
Let the HST do your braking, it’s not a car or truck.
7,334
I have no idea what you are suspecting but fix your brakes.
7,349
I guess I was hoping it was something easier than the 15 hour job of tearing in the rear end
BX brakes have been seldom covered here on OTT to my recollection. Have come up a few times
Wish you the best for repair.
I’d probably try to stop my use of the brakes…..😉 Not what they were designed for, if I had to guess….
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
182
Attalla Alabama
mossycreekoutdoors.com
Hydrostat should provide all the braking you could need even going downhill. I live on a mountain and barely any flat ground and never use my brakes driving. Now i do heavily depend on them for parking brake. If you've adjusted them then im afraid a long job is in your future
NickAdams
B-2400 HSD
Jan 11, 2021
74
23
My brake rod got bent and the disconnected from the brake lever - easy fix. Doesn't sound like your fix is going to be easy.
