BAD AIR
billwiley
l48 with bt1100
Apr 21, 2025
locust nc
Replaced a few hyd hoses on bt1100. I FAILED to fill the new lines when installed. Now it won't move and i'm scratching my head. Dealer says fill with oil and keep working it. Air will escape on it's on. Well I've been working it for two days and still nothing. Dealer also said there are no bleeder valve on that unit. I did notice there are ports with allen head plugs where fluid goes in the end of cylinder. Is that where I need to be?
Thanks in advance
waldo
L35
Jun 13, 2010
642
697
CT
They will self bleed, usually within seconds of replacement. Something else must be going on. Your hydraulic fluid level is up to spec?
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
Thanks in advance
waldo
Honestly as stupid as It sounds make sure your hoses are 100 percent connected properly. Unhook hoses and Physically push in on detent with a rag on a piece of wood make sure they will release and seat back properly. And if hoses are hooked properly does the hoses that supply that backhoe flex like there is fluid going to it ? All else fails crack some fittings will make a mess but at least you can see where the fluid is getting to
billwiley
l48 with bt1100
Apr 21, 2025
locust nc
problem solved sometime people do stuff in a hurry. Mitjam got it. I'm not going to tell everyone I had the lines crossed. DUH Thanks for your help
Happy Tilling
