L2502 review
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
One week ago, I traded my b2601 for a L2502. I'd like to share my impressions.
The bh77 is definitely an upgrade over the bh70. The added reach is noticeable. The 180 degrees swing is a big improvement. 24" bucket makes digging faster and the "power" of the backhoe is a lot better. Having a second seat makes it easier than to have to swivel the seat everytime, but it is now very difficult to control the backhoe by just turning around when wanting to do a quick job. Overall, the bh77 is definitely an upgrade over the bh70.
The tractor feels a lot heavier and bigger than the b2601. A bit more difficult to manoeuvre and harder to see in front of the bucket but it is more spacious and comfortable.
But it feels like the engine might not be powerful enough for this tractor size. For example, with the b2601 I could drive up a 14% hill on "H" but it is impossible to do this with the L2502. Even on "M", then engine bogs down. The "H" gear is mostly just for flat surface. I also feel like the b2601 was faster on the road at "H" vs the l2502
From what I understand, power is torque X speed. The l2502 is 25hp, just like the b2601, but as more torque, so I guess it means it's slower.
I like my new tractor, but I think I'll have to learn to use it more slowly.
10,250
Isn't the L2502 close to twice the weight of the B2601? I think it's around 1.75x heavier. The L has a larger displacement 3-cylinder engine, and no doubt more torque, but basically the same hp but a lot more weight to haul around. Kubota's literature lists top speeds of 12.7mph for the B2601 and 11.5mph for the L2502, so on paper at least the B2601 is faster.
Perhaps you'll be a candidate for one of @Rdrcr's turbo kits. It's one heck of a kit for a very reasonable price, and I know that I would buy his kit if I had a tractor such as an L2501.
awesome
Sep 16, 2018
320
215
ottawa
That's what I was thinking. Lots of weight to haul for such a small engine. Maybe the 39hp would have been better but we're jumping into a whole new price range
3,548
2,148
Curious, I did a little research. You can get 4 Kubota models with ~25hp.
BX2680.24.1hp @ 3200rpm 1001cc 1,521#
B2601....24.3hp @ 2800rpm 1123cc 1,632#
LX2620..24.8hp @ 2500rpm 1305cc 1,775#
L2502....24.8hp @ 2200rpm 1,647cc 2,811#
I think these numbers are fairly accurate.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
41
247
MN
I have a L3902 and it doesn't go up hills in 'H' either. Does fine in 'M' where I do most of my work. Sometimes I wonder if I coulda saved a couple $K and suficed with the L3302 model.
Most will say the HP is really only noticeable on PTO driven implements. I figured error on the higher HP side.
Rdrcr
Vendor Member
May 7, 2021
747
912
WA
I don’t have a backhoe but, my experience going from the B2601 to the L2501 is similar to yours. Yes, the L2502 will struggle going up steep hills in M at the stock power level.
With the S2T Turbo Kit, my L2501 is producing 44.1 HP and 35 PTO and doesn’t have any issues going up steep terrain in M carrying loads.
If you have some time, you’re more than welcome to read my thread;
Mike
awesome
Sep 16, 2018
320
215
ottawa
@MotoBBQ : how about pushing on a pile of dirt? Can you do this on "M"?
I don't really understand why HP would only be about PTO. Surely it says something about how the tractor can push or pull on things. Unless they all use the same hydro pump for the HST transmission.
But then again, my small tractor-mower is 21hp. I don't get it.
3,548
2,148
@MotoBBQ Surely it says something about how the tractor can push or pull on things. Unless they all use the same hydro pump for the HST transmission.
I think the 2502, 3302, and 3902 use the same hydrostat unit, but they have different gearing on the input/output. I'd like to see someone increase the speed on the 2502 from 2,200 to 2,700rpm to match the 3302/3902. I started some part # comparisons one time that led me to think changing a couple of gears, possibly with some modification, to get the PTO speed back to 540 would work (only on HST model). The top travel speed would increase but, with hydrostatic drive, this wouldn't be an issue.
The L2502 engine at 2700rpm with proper fuel control should produce 35hp.
jyoutz
Jan 14, 2019
3,495
2,583
Edgewood, New Mexico
I don’t drive on the road much for transport. Whenever I’m on the road, I’m grading or plowing it in M speed. Just use M for hilly roads and it will be fine.
6,287
H range on an L3901HST is worthless. On paved county roads at full RPM even a slight incline drags the engine down. I operate mostly in M and L is used for climbing mountains or pushing heavy piles of material.
PaulL
2,675
1,668
NZ
Normally HP is about PTO because most of the smaller Kubotas don't have a lot of traction. So more HP doesn't let you do more - it just lets you spin your wheels faster. And they can't lift more, that's controlled by the hydraulic pump, and most of the models in a series all have the same hydraulic pump. So PTO is the place you definitely use more power - snowblower, chipper etc.
However, when you're at speed, you can also use the HP just driving. So pulling a load up a hill, yes, more HP matters. Just dragging a heavy load from standstill, or pulling ground engaging equipment, no, the limitation is usually the tires.
