Hydraulic functions problems
MyAxleBroke
R400
Oct 13, 2022
New york
My R400 backhoe attachment works very well. The only complaint.
The swing function doesn't have much power side to side, unless the boom is full up, holding pressure up and swing together plenty of power. Is this a design problem or something that is fixable?
It is a pain to full boom up all the time to get any swing with power.
Thanks for the help.
5,184
As I understand it, the hydraulic flow on many of these small BHs, is because the hyd pump is sharing flow with another function.
7,050
Power or speed?
2,990
I have 2 I looked and there isn't a section titled that's your problem.
lol thanks
They do have a trouble shooting diagram at the end of the section that could be helpful to at least eliminate some possible problems.
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
Let me preface this by saying I have no knowledge of your specific model BH.
That said, it is common backhoe hydraulic circuits to be sized for different flow rates in some of the lines to balance speeds when using multiple functions at once. This helps the operator make smooth movements and prevents once function from robbing others of all the fluid.
Secondly, if your BH has a "open center" type hydraulic system, then the pressures in the system are near zero when levers are all neutralized. The pressure climbs when cylinders are operated up to the maximum relief valve setting -- as when a cylinder hits the end of it's travel.
I wonder if the swing function on yours is deliberately limited for smooth operation (and perhaps guarding against overstressing the boom when swinging against something) but the speed/power increases when another cylinder (in this case the boom) hits the end of it's stroke and increases the pressure to max?
7,050
That kind of ptotection is usually provided by port reliefs and I dont see any in the parts book.
Assuming the backhoe valve is a standard parallel type the pressure/flow goes to the least loaded spool in the set.
What we "know" is the pressure/flow increases when the boom cylinder is deadheaded. That suggests the boom circuit is somehow bleeding off pressure/flow.
A hydraulic circuit diagram would help immensley. Diagnosing this is going to tequire understanding oc the finer points of hydraulic Circuit operation.
MyAxleBroke
R400
Oct 13, 2022
New york
MyAxleBroke
R400
Oct 13, 2022
New york
Sorry for dropping the ball on this life is very busy. Your summary is on point.
Best pic I could get.
Thanks for the help
ruger1980
L4310 w/La682, L225
Oct 25, 2020
569
247
CNY
Can you get a clearer image of the detail of the valve section in the schematic? The spools are a bit blurry and they are hard to make out.
I almost forgot is you machine set up for JD/Backhoe controls or Cat/ISO? If ISO were the boom and arm valve sections swapped?
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
The second image seems to show some sort of port relief valves installed on several circuits, labelled "b1", "b2" etc. "b5" and "b6" are associated with the swing cylinder.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
569
247
CNY
It appears this is normal operation looking at the clearer schematic provided by @MyAxleBroke. If you look below at the drawn over copy you will see that when the swing spool is shifted it does not fully block the center passage like the other spools do, it only restricts the flow. This will make swing slightly slower and weaker than the other functions and when the boom spool is shifted it will block the center passage. When the boom cylinder is at the end of travel it will provide full flow to the swing function and will create the symptom that you are experiencing.
