Good deal. Did you get a tailstock?My latest acquisition, a Phase II 5C Indexer, Not quite as nice a a Hardinge, but WAAAAAYYYY less expensive.
70mm centerline, 2 1/4" - 8 spindle nose, tight & smooth. $100 shipped.
View attachment 140301 View attachment 140302
No, but I have a tailstock from a dividing head that is adjustable for height & tilt that will work.Good deal. Did you get a tailstock?
I have a much newer unit with a helical like you have, I LOVE IT!Next came adjusting the 4-post height for an even cut from side to side. (No more adjusting the knives for an even & level cut.) The hand crank on one jack screw in one post is connected by chain drive to the other three. The threaded nuts on the jack screws were connected to the four corners of the top framework which holds the cutterhead. When the chain drive/jack screw was adjusted on one sprocket it affected the level on the other three posts. After days of swapping those jack screw nuts around, swapping the sprockets between posts, and then moving the posts’ gear tooth engagement to the chain….the planer is now only off “4 thou” from one side of the bed to the other. (I planed a narrow board flat on one side. Split the board in two. Then ran them through the planer at each edge of the bed. Measured the final thickness of each piece with a digital caliper.)
View attachment 149368 View attachment 149369
I don’t think the cutterhead had ever been set up as nicely as it is now. Any past discrepancy could have been accounted for in setting/adjusting the knives in the old holder. How does the Shelix cutterhead perform? It leaves such a smooth flat surface, almost like glass. While it’s new, anyway.
It does such a nice job that the old Delta long bed jointer is going to get the same treatment, in the near future. Shelix makes a replacement cutterhead for that also.
I have, and I agree! Nice to hear your experience confirms what I am hoping for!!I have a much newer unit with a helical like you have, I LOVE IT!
Take a piece of OSB and run it through the planer.
It should shock you at how smooth it will come out, I know it did me!
I have used mine for three years and still have not damaged a single tooth.
I have a custom rolling metal table for my Delta portable Unisaw, it was a rare contractor model.I have, and I agree! Nice to hear your experience confirms what I am hoping for!!
Most likely this like new 40+ year old machine will wind up with one of the sons after I'm long gone and still be going strong for another 40 years.
I also gave a complete ground up restoration to my same vintage Delta Unisaw. Motor and controller rebuild with new bearings, contacts, etc. Saw was stripped to the bones and put back together all cleaned up with new trunion bearings, arbor bearings, etc. Even the homemade moveable base was cleaned up and finally painted. A First for me!! LOL! Now to get after the jointer/planer!!
I could use that right now. Instead it will probably be a tree, chain, and the loader on L3901....I've enjoyed this thread since @Lil Foot started it many years ago.
This doesn't really fit here but not worthy of a new thread.
I acquired a new tool. 10-ton Vevor Porta Power, so it's a cheapie import. In a recent thread, a porta power was discussed. I said then I'd been looking.
Worked out of the box, so that's a plus....Applies force by expansion and contraction (pull-in). Has several attachments/extensions, etc.
Directions (I called them Destructions) in the box are actually decent.
Was surprised the box probably weighs close to 60 pounds....pretty heavily built. How WELL built is another subject.
I don't have a routine need for one, but there's been many times I wish I had one. I can get creative with a bottle jack, but sometimes I need something else.
For $154 plus tax delivered to my door, was worth the risk.....
Dan - -I could use that right now. Instead it will probably be a tree, chain, and the loader on L3901....
I have a goodly number of HF tools - I dont think you will break that porta-power.Dan - -
Trust me, if you were closer, I'd deliver it to you so you could use it.
Then I'd blame you when it broke.....
Just poking fun.
Hopefully a tree and the L3901 will work for what you have at hand.....
