Grapple Claw storage?
Blue2Orange
Apr 3, 2025
405
283
Bayview Township
Is it best to store for both short (days) and long(months) term with the grapple fully open resting on the lower and upper tines? Or can I just leave it when detached with grapple closed and upright? Stored inside the garage. LandPride short video demonstrated removal. Presenter opened up grapple and set it on the tines before detaching. Understand it would be a more stable. But even closed and upright on a concrete level surface it seems stable.
11,755
Figure out what's important to you and decide based on your priorities.
  • How easy is it to get it on/off the tractor
  • How much space does it take up when it's off the tractor
  • How stable is it when it's stored
  • Is there a need to protect the cylinder rods during storage
I recently made up a "kick stand" to support the EA 60" Wicked grapple. This particular model won't stand up on its own when it's closed and off the tractor. I don't need to worry about the cylinder rods during long term storage because corrosion isn't an issue up here. I want the grapple to be easy to get on and take off, I want it to fit on a pallet, and be stable when stored.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I store mine open with the claws into the ground. I just want the cylinders retracted so the rods stay corrosion-free.
Bmyers
May 27, 2019
3,616
4,876
Southern Illinois
My friend built me a rack that holds my grapple at chest height. I can easily see to connect/disconnect, it has safety chains on the rack to prevent it from being knocked off.
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
199
116
Ellicott City, MD
That's slick. I just received my 55" Wicked Light grapple and will follow suit if needed.
Andreas
11,755
Andreas
Nice! Out of interest, when did you order it?
You can see more of the kick stand in this thread, and one a few posts before it.
AOW162435
Jun 16, 2023
199
116
Ellicott City, MD
Ordered 3/27/2025, received 4/17/2025.
Andreas
3,792
2,350
The instructions with my SGC1060 say to store it fully open on the tines. But it takes up a lot of floor space and is hard to attach, so I store it standing up on the concrete floor. It's pretty stable, but I wouldn't have kids around it. Outside, I'd follow the instructions.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
125
122
Lakes Region, NH
My Land Pride SGC0660 grapple has fold out stands on either end so it sits stable in the upright position while closed. I store it inside on a dolly so I can move it around easily and keep it out of the way.
Blue2Orange
Apr 3, 2025
405
283
Bayview Township
Grapple and snowblower along with the BX sits inside a garage when not in use. Grapple seems stable enough standing upright. Box blade, back blade, and dirt bucket sit on pallets outside. First thought when I brought OldBlue home back in '01 is I should have built a larger garage. Barely made it in with the ROPS up. The tractor with loader occupied the space that NewOrange and the couple implements sit with walking around room and a space to store the box scraper and back blade. But the need to attach, detach an implement to get to the one in back will be a bit of a pain. Still wish I would have built a bigger garage.
Recycling a pallet to mount casters on it for moving the snowblower around without needing to attach it to the tractor. If it works out fine. Will build a similar platform for all the implements but the dirt scoop.
Donystoy
Dec 10, 2013
730
375
Binbrook, Ontario
I just screwed an appropriately sized sheet of plywood onto one of those cheap larger four wheeled dolly's and placed the grapple tines down and partially open. Works great and not too wide.
AOW162435
Jun 16, 2023
199
116
Ellicott City, MD
I created a facsimile of your stand today. Will post pics once it's done. Thank you for the idea. 👍🏻
Teaser:
Andreas
bird dogger
Vendor Member
Feb 24, 2019
1,789
1,766
North Dakota
My EA 55" Grapple dolly build is Here
Already been 5 yrs since first built. On my concrete floor it sure is nice to roll it off to the side when not in use and right up to the front of the tractor when it is needed for a quick hook up.
bird dogger
Vendor Member
Feb 24, 2019
1,789
1,766
North Dakota
That's a great idea!! And perfect for when I use the tractor at our wood lot a couple hours away. Nice to have both the bucket and grapple along, but hate having to dig the grapple out of the mud after its either fallen over or sunk after a few days of unexpected hard rainstorms!! Another project added to the list.....
AOW162435
Jun 16, 2023
199
116
Ellicott City, MD
Very nice!
Andreas
AOW162435
Jun 16, 2023
199
116
Ellicott City, MD
Nice! Looking forward to seeing the rest of it. (y)
Finished & works as intended. Rock solid. Thank you for the inspiration.
Andreas
11,755
Andreas
You're welcome, and really nice work. I like that you repurposed what appears to be an old draw bar. It's always fun making something useful from steel in a scrap pile.
