B5100E cranks slowly
OntheRidge
Nov 1, 2020
409
479
Posting this for my brother. He has a 1982ish B5100E. Disclaimer: All info is through him to me, he is not tech savvy but pretty mechanical.
When he cranks it with compression release closed, it turns very slowly. When open, it cranks fine. New starter, good battery, all wires and terminals verified good. Also when jumped direct to starter, same symptoms. I will try to get additional info from him as needed.
Any thoughts? Thank you!
5,277
Working exactly as designed. Read the description of starting procedure in the Owners Manual.
OntheRidge
Nov 1, 2020
409
479
It won't crank fast enough to start, problem has got increasingly worse.
OntheRidge
Nov 1, 2020
409
479
I'm working long distance, he's in Maine, I'm in WV. Not sure he has a manual. Should it start with release open? Thank you, sorry for the lack of clarity.
2,060
It will NOT start with the release open. Steps to start would be something like pull release knob, preheat glow plugs, turn switch to crank position, let engine spin up to speed and push knob in (holding key in start position). The inertia of the engine should help it spin faster and start the engine. If it doesn’t start, try the same sequence again, don’t just keep trying to crank it against the compression.
Where did he get the new starter? Is it spinning the engine the same speed as the old starter or is it faster.
Have him verify the negative cable end that attaches to the tractor is clean and shiny on the tractor and the cable.
What was happening last time it started well, and what has happened since then until the problem started?
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
222
236
Pennsylvania
Are the glow plugs working? Mine starts instantly when glow plugs are hot....
OntheRidge
Nov 1, 2020
409
479
As it turns out, a varmint had built a nest in exhaust, almost completely blocking it. It now starts fine! Thank you all!
2,060
Well that’s one I don’t recall hearing about before!
Do you know how he figured that out?
OntheRidge
Nov 1, 2020
409
479
I think he removed exhaust to check, mostly out of frustration.
