RGR1258 Tiller Vent Plug
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
The past couple times I have used my RGR1258 tiller, I have noticed the gear oil looked milky white. The first time I noticed it, I removed the plate to the gear case and cleaned out the milky oil and put fresh oil in. I used it to till my garden. Then about a month later I noticed it looked milky again. So I opened the gear case again and it was, in fact, milky white. I cleaned it out again and replaced with fresh oil. I checked the rubber gasket between the cover and the body of the gear case and found it to be in good shape. I removed the vent plug and thought maybe moisture is getting in there. I also noticed after using the tiller, gear oil runs out of the vent plug hole. I only put the required 3 qts / 6 pints in there. So I know it doesn’t have too much oil in it. At first I put thread tape but then removed it because that would defeat the purpose of the vent plug. So I am curious, is there a liquid sealant I can put on to keep this from happening or is this just part of it?
3,716
Where is it stored? I
Inside or outside?
I was originally thinking that condensation was your problem, but I have a difficult time believing that much condensation would form in one month.
But I suppose Georgia is a lot more humid than Michigan is.
I am just "spit ballin" here, are you sure your putting the gear oil in the right place?
Gear BOX is 2 pints.
Gear CASE is 6 pints.
Just an observation.....
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
Inside or outside?
It is stored outside. Yes, I am putting the 6 pints / 3 qts in the gear case. The one that is on the side of the tiller, not the gear box on top. I just can’t believe there isn’t a better solution than what I have heard from others which is “just change your oil after use”. That to me sounds like a waste. There has to be a solution to keep water out. Could it be a bag vent plug? Also, why would oil be leaking out from where the vent plug is when I am using the tiller? It isn’t over full
3,716
Here is another "thought".
Are you sure you are draining out all 6 pints?
I had a situation about 2 years ago when I bought my "oil sucker".
I used it on my wifes minivan and I sucked out all the oil first through the dipstick tube, then dumped it out.
Then I unscrewed the filter cap and replaced the filter.
However when I went to refill it, I could only put 5 quarts in before the fill mark on the dipstick was reached.
Hmmmmm.......Thats odd, I would have bet my life that it took 6 quarts..........
Long story short.....I called my BIL, and he told me that by not draining it out the bottom, a "Vacuum" develops in that engine, and 1 full quart is trapped.
Instead, he informed me that I need to take the filter cap off FIRST, then suck out the oil to get all 6 quarts out.
He was right.
Maybe something similar is happening to you, and you are leaving some in, and accidently overfilling it?
Just a hypothesis.
EDIT: The above scenario would also explain why the oil gets "milky" right away. Cause there would always be some "milky" oil in it, contaminating the new oil.
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
He was right.
Just a hypothesis.
Mine doesn’t have a drain plug on it. It only has the fill plug/vent plug up top. It has a site window on the side of the cover. So in order to drain it I have to remove the whole gear case front plate. So yes, it is completely drained and I wipe it down to make sure all the milky gear oil is gone before I replaced the cover and refill it.
5,725
re: Great way to destroy equipment.
Not always true. My tiller's been outside for 16-17 years and still a 9 out of 10 ( -1 from USING it ! ). The rear blade was 60 years old, 3 furrow plow almost 70. All 4 tractors from late 50s, all function great.
Older farm equipment was built to last( real paint, thicker tin,etc.)
As for the vent,if your add 2 'street elbows' to form an upside down 'U', that will prevent rain water from getting in.
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
Great way to destroy equipment. If you want your stuff to last find a spot indoors to park it. Building a mouse condo with plastic wraps doesn't solve the moisture problem storing outside.
Yes, I should probably build something to store my equipment in. I wouldn’t wanna keep it like the dealership does for years sitting outside on their sales lot. Ha ha. I guess it’s fine for them. Anyways, I still don’t understand how the vent plug is causing all the moisture to get inside the tiller. It seems like not a great design.
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
Yours has been the first helpful comment. Thank you very much for the advice. What kind of pipe? And will I have to put anything on the threads or just screw them in to the top where the vent plug goes?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
512
199
CNY
Have you looked at the gasket and shaft seal at the upper input shaft bearing? Either of those could be a source of water ingress. Condensation is not a likely cause of that much moisture in your oil. Also what kind of gear oil are you using and I assume you checking it before use?
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
I checked the gasket but not the shaft seal. I use the recommended oil from the manual, 80-90. Yes I check the sight glass before each use. If it looks milky I don’t run it until I swap out. I called land pride and they said with the metal vent plug, I should be fine putting thread tape on the threads.
2,153
There are many different types of vent plugs and some are more weatherproof than others. You could try to change it to something like this (shown below) that is the correct size or just put a plastic or metal shield over yours when it is sitting around (think butter tub or bucket whatever fits best)
3,716
What the heck you got your ole lady driving that aint got a drain plug?
Oh it's got a drain plug for sure, but since I bought that "oil sucker" for the boat, I have become even more lazy, and found "other uses" for it.
Like these motors with the "cartridge" type filters, that are accessible from the top.
Now I don't even have to put it on the hoist......Just pop the hood, swap out filters, suck out the oil, refill it and go.
Takes about 4 minutes to change the oil....Hell, I do it when she stops to 'drop off the groceries' between shopping runs now..
It's "stupid-fast and easy" :p (y)
5,725
Here's a 'street elbow', you'll need 2 of them.
Simply remove the 'vent plug' (#31 in the parts diagram...) and take to local 'plumbing shop' and buy 2 street elbows.
Screw one into the hole where the vent was, the other street elbow into the 1st, the vent into the 2nd.
No need for pipe dope or teflon tape, it's 'optional' !
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,634
1,898
Near Lancaster, PA, USA
I have no experience with that equipment, but was curious enough to look around a bit. If this is the type of vent you have, it wears a little rain bonnet and my guess is that the vent itself should be fine as long as the threads are sealed. The cover the vent screws into has a shape that looks like it would shed rain water. Make sure the vent can breathe. If you park it hot and you get rain, it can potentially create negative pressure inside and suck rain in through small spaces.
I'd check that flat cover on that gearbox. I've had water infiltration on similar gearboxes on mower decks. The mating surfaces where the gasket are important but also check how it seals around the cover bolts. The flat cover would allow water to sit and seek a path under the bolt heads and into the gearbox.
BBFarmer
Jul 12, 2024
665
1,291
Terry, MS
What is this great sucker you speak of?
Always looking for a better way to suck if I can.
Have several different versions/styles around the shop. Pumps, pneumatic.....Try to keep different ones for different fluids different situations, sucking, filling, flushing, bottom side fills, etc.
jeremyzcook82
L2501, RGR1258
Apr 14, 2025
Georgia
It sort of looks like that but more like an umbrella because the sides are crimped inward. I don’t see a hole in the bottom of it when I take the plug out, so I’m not sure how it vents. I have also tried blowing on the bottom of the plug, but again, with no hole in the bottom the air doesn’t go anywhere.
chim
Jan 19, 2013
2,634
1,898
I've seen vents with filtering material that made them appear to be plugged. They don't need to pass large volumes.
Check sintered vent plug.
3,716
https://www.hodgesmarine.com/jab178...7AcZUtzKXfrQ9dtOxe94PJKNaPgyP3dc7RmvWIXcoHme_
Jabsco Diy Oil Change System W/Pump & 3.5 Gallon Bucket
Friend of mine owns a marina and this is the one they use.
There are tons of others out there, but I went with this one based on his recommendation (and 40 years of experience.)
