My pond/Food Forest
Scm
BX23S
Sep 28, 2024
444
412
Missouri
This is the current state of it. Started last year with my B8200. Continuing on with my 23s. The picture does not do it any justice as to just how steep everything is.
Reactions: 8 users
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Said the same thing taking a pic of our pond dam this weekend.
Picture made it look like nothing, meanwhile I can barely walk down it without falling.
Looks like you got something good going on though. Keep the pics coming, love seeing progress.
7,717
That's quite a project for a B8200. Looks like you're going to need a terrace above the pond to keep it from silting in.
Scm
BX23S
Sep 28, 2024
444
412
Missouri
What is a food forest????
While I am not endorsing this project, this is a good description of it:
"A food forest, also called a forest garden, is a diverse planting of edible plants that attempts to mimic the ecosystems and patterns found in nature. Food forests are three dimensional designs, with life extending in all directions – up, down, and out.
Generally, we recognize seven layers of a forest garden – the overstory, the understory, the shrub layer, the herbaceous layer, the root layer, the ground cover layer, and the vine layer. Some also like to recognize the mycelial layer, layer eight (mushrooms). Using these layers, we can fit more plants in an area without causing failure due to competition."
Scm
BX23S
Sep 28, 2024
444
412
Missouri
I need terraces everywhere. All clay and rock so not too much wash out though.
11,272
Ok, gotcha. ;)
7,356
Interesting. Be curious how it works in practical implementation.
We have a local edible mushroom producer that might be implementing some of the principles....
3,156
Food forests are part of the permaculture world that a lot of people have implemented in their “homestead”.
See this link (if you are interested) for one person’s experience and “inventing” the permaculture movement.
Scm
BX23S
Sep 28, 2024
444
412
Missouri
Thanks for that. I didn't like using the term "permaculture" because I don't like talking about science and politics. Holtzer is more my style.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
I was hoping someone found out how to grow steaks and ribs on trees 😔
Reactions: 7 users
Scm
BX23S
Sep 28, 2024
444
412
Missouri
This is last year when I started with the B8200. That thing had great torque.
Scm
BX23S
Sep 28, 2024
444
412
Missouri
Getting there. Another day or two. Hit rock bottom @ 9'. Not trying to make it deep, just needed the material. About 90' across so far. will be about 110' when done. The pic is so deceiving. Just to the right of my tractor between the two green spots, the slope is probably 60 degrees. Further to the right (tire tracks) where I exit the hole. the slope is probably 40ish degrees.
Reactions: 9 users
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
I'm confused. After a year a runoff pond should be full. Are you going to have to pump water in to fill it, are you in a drought, or does it need bentonite to seal it?
Scm
BX23S
Sep 28, 2024
444
412
Missouri
I diverted the runoff and have been draining it when it gets water in it. I don't want it to fill until next spring at least. The backside of my dam is probably over 12' tall. Would like for everything to settle first.
Scm
BX23S
Sep 28, 2024
444
412
Missouri
Been working on my irrigation system before the drought hits.
I dug a pond at the top of the paddock last year. I installed a 3/4' pipe 425'/40' fall from the pond to the first tank. I use a natural siphon and a float valve to keep it full of pond water when available. There will be a backup hook up to the well that will be on a timer to only fill at night.
I have a water meter connected to tank 1, so I know my usage. From there it goes to the first part of the food forest and splits. One line goes to a timer that runs the top part of the system when the sun comes up for one hour. The other line goes to tank two. This 2500 gal tank is filled primary buy the house roof. Secondarily will be from the tank 1. It too has timer that comes on at sunup for one hour.
The line between the flower/food forest area to the future food forest area is there so the water in tank two can help feed the flower/kitchen gardens due to the way the elevations work out. without that line the 2500 gal tank would of only feed half the crop garden and the orchard forest.
The system is not completely finished yet. 75-80% done.
Done on a budget.
I'm currently using 105 gallons a day.
I expect when done 150ish a day.
That's 27 days of water storage in the tanks alone.
One future plan so far is to make the pond at the top bigger. at least 2X
Saves about 2-3 hours a day of hand watering.
The drop from the pond at the top to the orchard is 80' ish
Scm
BX23S
Sep 28, 2024
444
412
Missouri
I expanded the upper pond that holds my irrigation water. at least 3x bigger. Just need some rain to fill it
