Bx wheel weights
skypros
BX23s
Jul 2, 2018
71
Bend, OR
Finally got the weights all finished.
Used 1/2" x 6-1/2" Carriage bolt to attach weight to the rim.... wish they made a 6-3/4" carriage bolt.... as that would of been the perfect length.
I also used some "leak seal" and applied it to the inside of the weight.... to put a rubber barrier between the rim and the weight.... Hopefully it will prevent the weight from scratching the rim.
The old bolts were only 6" so the garden tractor that they were most likely attached to was not as deep of a rim.
The weights fit rim PERFECTLY !
B737
LX3310
Jun 9, 2019
2,022
2,205
those came out awesome!
lunasdude
Kubota BX1880, FEL, quick con pto, box bld, land plane, flail mower
Dec 22, 2018
55
Los Lunas, NM USA
Look great!
You did good!:cool:
lunasdude
Dec 22, 2018
55
Los Lunas, NM USA
Looks great!
You did good!:cool:
4,287
You could do like I did and use 1/2 all thread and you can make them any size you need
5,154
I use Chevrolet orange engine paint, since it matches the Kubota orange perfectly, and I also have a 1962 Chevrolet, and always have the paint in the garage for touch up on my engine.
Your weights look great, and when I fist posted, I wasn't even thinking about the Bolens weights. I recently sold off my Bolens HT20, and when I got it out of the back yard, I found the wheel weights near the tractor. I will probably put them on my tractor at some point, even though I have my rear tires filled with beet juice.
Bearcatrp
Mar 28, 2023
955
603
Minnesota
Looks good. How do they mount? I see the 2 bolts how does the bolts attach to the rim? Got a link to where you bought them at? From a quick google search, I found 50 lbs each from eBay. Are yours 50 lbs?
7,051
The Kubota BX wheel weights aren’t a good setup in my opinion. Plastic, typical garden tractor weights. Mine were 50#.
I got a set when I bought the tractor new. Never put them on and sold them cheap to a friend with a BX.
The operator manual doesn’t recommend weights on tires with liquid ballast.
I didn’t put them on more since I didn’t care for the weights or how they mounted. Also, didn’t really have an urgent need for more wheel ballast.
t_goff
Kubota BX 1880
Apr 12, 2025
Humboldt County, CA
They mount with 1/2” x 7” carriage bolts. I used galvanized carriage bolts. They are inserted through the rim which have 4 square holes for this purpose. The weight fits against the rim and the two carriage bolts hold the weight on with clamping force.
The two weights were both at 50lb and I got them off of eBay. I prefer them to liquid ballast for my purposes and I am very happy with them.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
385
371
Amsterdam, NY
Great looking job on your weights.
I used an old set of Craftsman weights 50 lb. each I had laying around. 4 pieces of 1/2" all thread, washers and nuts. Didn't paint them since they're plastic. They're not flush like yours but they were free to me.
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
I turned mine from some scrap slugs. ~50# each, 2 per side so I've got about 200# and they don't stick out past the tire to catch on things.
Bee-Positive
Nov 16, 2022
385
371
Amsterdam, NY
Those look store bought, nice job. I like the notch you cut for the valve stem.
Side note - I don't want to steal the thread but how'd you attach the fire extinguisher bracket to the ROPS?
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
Thanks, notch cut with 1.5" ball end end mill. Plastic extinguisher bracket screwed to 1/8" plate attached to ROPS with neodymium magnets.
