L2502 QD couplers
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
293
203
ottawa
Can someone confirm what types of QD couplers are used on the hydraulic hoses of the BH77?
The part diagram shows "Kubota NIPPLE, 3/8 NIP HNV28NPTM - 7J417-66220"
I believe these would be 3/8 iso7241-B. Correct?
I'm in Canada if that is useful to know.
5,099
Those are Faster HNV (ISO 7241B) couplers.
Donystoy
Dec 10, 2013
661
299
Binbrook, Ontario
You should not have this issue if staying with Kubota fittings but when I converted my BH77 to pto pump driven hydraulics I had to use additional quick connects. The 3/8 male end that I tried to use looked identical to what was already on the tractor but just would not latch into the female end. I ended up purchasing one from the dealer which worked fine. All I can think of is that the tip of the male fitting would not push in quite far enough. Might have worked if I had filed a bit off the tip though.
