RPM for bucket
Todd R
LX2620HSDC, LA535, B2371
Apr 11, 2025
Greetings!
New tractor owner here. LX2620HSDC. What is the correct RPM for running my LA535 with B23671 bucket? I can find no useful information in my Owner's Manual, and YouTube will drive you nuts. Thank You!
11,280
There is no set RPM.
You run the tractor at the RPM needed to do the job.
you're either running it at too low of rpm or working it too hard.
If it keeps stalling or you can't do what you want to do you're running the RPM too low, or the job your trying to do is bigger than the tractor you have!
7,366
Congratulations and welcome to OTT!
I just saw an LX2620 at the local dealership with a front-mounted snowblower. Nice machine!
I do not believe that the LX2620 has EPA Tier IV emissions equipment (DPF).
As such, you don't need to be as concerned about lower RPM fouling the emissions system.
You want enough RPM so the engine doesn't "lug." That's not good.
Looks like PTO-rated RPM for the LX2620 is 2,500 engine RPM. That 2,500 would turn the rear PTO at 540 RPM and mid-PTO at 2,500 RPM.
Here's the specs I was referencing: lx20_specs.pdf
The loader hydraulics will have the same lifting/curl force at 50% throttle as 100%, it just moves faster at 100%.
I'm guessing some. Without knowing your skill level, I would probably start at half (2/3?) throttle. Adjust as needed. Will also depend on what you're doing with the loader (heavy/light, need to go slower for "finesse," with forks, etc.)
I've had a BX with loader for 12 years now. I seldom look at the tachometer. I simply adjust the throttle for what I'm doing.
PS - - @North Idaho Wolfman was typing while I was...... ;)
Reactions: 6 users
7,361
The higher the engine speed the more pushing power you have and faster the loader will raise. If I am doing REAL loader work I set engine RPM close to max. That gets me good loader response and full pushing power. Ground speed is easily controlled with the HST transmission,
Reactions: 6 users
Todd R
Apr 11, 2025
Thank You All! Real newbie here. Have 5 hours on the tractor, so VERY little experience. I will not be pushing it until it's 50-hour maintenance. I am SO glad I joined this forum. Thanks again! Todd
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
647
1,870
Vermont
youtube.com
I'm a newbie too and honestly....I ran it at a slower RPM to get used to the controls and just took my time. Once I felt more comfortable with the operations I increased the RPM. It makes the cycle times of the hydraulics much faster and a little more sensitive. The first time you raise the bucket and accidently lower fast is a pucker moment 🤣 I think everyone experiences this a few times, even experienced operators.
But I do know that when running it at a higher RPM makes everything just run more efficiently and you get a little less HST whine as its pumping more fluid and obvisually you get a little more power.
For the range, this is what I was taught and I think its a good method to follow but doesn't always necessarily mean you have to follow it to the T. Its just a good guideline to follow.
Low - Loader
Medium - Mowing
High - Highway
I have done some loader work in medium range, but it wasn't anything hard just really light stuff...like snow or some organic material like brush or leaves. I know some people will switch to low range to scoop up a big pile of dirt and then move to high range for transport if the distance is far but you have to be careful when using high range with a full bucket...it gets sketchy and bouncy haha.
You just have to use you're own judgement and use plenty of caution. YouTube is the biggest resource and its worth watching a lot of operational content on these machines. It was helpful for me.
Nothing wrong with taking it easy at first until you get comfortable. The man in us just wants to send it lol But take your time and have fun and most importantly...be safe.
Hope this helps. Just trying to share what my "newbie" experience is so far.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Heck yea brother.....Get out there and give her the beans!!!
7,366
Dan brings up a great point.
I was focusing more on loader operation, but Dan brings up operation of the tractor itself.
Higher engine RPM makes the HST tractor more responsive.
For lack of a better term, an HST can be a little "anemic" at low engine RPM.
I regularly get loads of stone for the driveway. About 20 tons every couple years. With some other stone delivered for foundation purposes, I've probably handled 120(?) tons over the 12 years I've had the Kubota.
30% of that is distributed with the loader bucket. Have to push into the pile to get a bucket full. Need nearly 100% RPM to help the tractor do that. Rest is pulled around with a box blade.
A loader can be very dangerous. Always keep loads/bucket low. Have a good ballast on the 3-point hitch as a counterweight. For your tractor, 400# or so would work. Could be an implement or a ballast box. I use an implement.
ALWAYS have it in 4WD when working on slopes. You don't have front brakes like a car or truck.
If you go down a slope with weight on the loader, you could lose traction on your rear tires.......if in 2WD you slide down the hill quickly...... Nothing to stop you....:oops:
If in 4WD, the fronts will help slow you down as they're connected to the HST drivetrain.....
As a veteran of 5 hours tractor usage, it's best to start slow and increase as skills improve. ;)
If your location is your zip code, I'm guessing you have some slopes. I used to spend a lot of time in Warrensburg while in college. Visit the area regularly. Love it up there. (y)
Todd R
Apr 11, 2025
That would be Putnam Station. Bought in '88, built cottage in '90 and finally added on and retired here last fall. All the time knowing I'd need a tractor when we were finally "full timers". I just put another hour on her, using all your tips. Thanks!
bird dogger
Feb 24, 2019
1,811
1,785
North Dakota
I was going to mention...but @RCW mentioned it above....
One of the most important if not the most important thing is to keep the loaded bucket as low as possible while doing your work. Keep it low between points A and B if your moving materials. Raise it up to dump only when you're at your destination...and preferably at a standstill.... until you get more time in the seat.
As a newbie, it wouldn't hurt to keep your right hand on the loader control lever and ready to shove that stick forward to dump and lower the load if things get iffy or feels tippy. It's better to pick up a spilled bucket load of fill than to have to upright your tractor and inspect for damages.
If your bucket is high up and a wheel drops into an unseen divot or hole....that could be all it takes to get to the tipping point. Keep the center of gravity as low as you can...and be extra careful when you do need to raise the bucket up high to dump. You'll gain experience fast, once you start using it.
Enjoy!! and be careful.
11,757
Greetings!
Everyone seems to have covered the basics so all I will add is to say, nice first tractor! :)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
With a heavy load in the bucket, I back down hills to maintain effective rear wheel braking.
5,691
Welcome to the orange! One thing, think about what you are going to do, then think it through a second time. Things can happen in a heart beat so just think it through and use it, don't baby her. If she sound like she is lugging bump the RPM up a bit, till you reach the point of her purring not screaming. It will all come, It takes time, everyone in here has traveled this same road. :) Oh and yeah keep the pictures coming we love out tractor porn,, Right wolfman,, lol
JonM
Nov 29, 2024
292
695
wisconsin
if you are operating with a load in the bucket go slow very very slow. the most dangerous thung you can do besides running the pto while off the tractor seat is using the front end loader for a lifting task
Survivor
L2501
Jun 8, 2025
46
Good rule of thumb...avoid lugging the engine!
Well, I figure the tractor is engineered to run all day at PTO rpm (mowing, baling, etc.)
So I will go a little down or up from there as seems to be required, but not too long above PTO rpm. Sometimes when skidding a heavy log uphill, and have to put it in low range, and crank it up. But keep the pressure light on the HST pedal to keep the effective gear ratio to the wheels as low as possible.
But no sense to go roaring down a hill in medium range when you can just drop down to maybe 1600 rpm, and mash that HST pedal a bit to get some ground speed. Also there are times in steep tight places that I put her in low range and run a moderate throttle just so that I can crawl around very carefully.
I will say that I don't like the friction throttle handle on the Kubotas. I would rather have the old ratchet style where you would eventually learn which notch gives you a certain rpm. The paint tends to wear differently to identify the sweet spots.
5,576
All good advice above!
Just in case you did not know, I would like to mention that there is a "detent" position called "float mode" on your FEL.
I am relatively sure yours will have it too.
If you push the stick forward to what appears to be it's max position and then give it a "little shove forward", you can feel it "lock in" and the FEL will drop down.
I mention it because I have a friend that had been using his tractor for years and never knew about it, until we were talking while standing next to his tractor, and I reached over and showed him.
My "delivery driver" showed me when he dropped it off....
Survivor
L2501
Jun 8, 2025
46
I haven't yet found that very useful. It tends to either dig in or rise above the intended grade depending on very slight changes in the bucket pitch.
With the snowplow blade on the skids, the front of the tractor just slides all over the place.
JonM
Nov 29, 2024
292
695
wisconsin
float takes practice thats for sure. onve you get the hang of it, its aweaome for scraping large areas.
6,880
Not much to add to all the excellent advice above. Only one thing, which was counterintuitive to me when I started with HST: If you’re running out of power, LESS pedal, not more, will provide more torque.
