Oil leak
tincan
Kubota l295dt
Apr 7, 2025
Conway arkansas
78 model 295 directly under the oil filter there is a round hole no thread looks like it has a plastic plug. When I start the engine oil squirts out any thoughts to the problem. Engine sounds normal.
5,170
If you order small parts from Messick's, be certain to request USPS shipping.
UPS will charge at least 500% more.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
666
275
Herald Calif.
I believe 40 plus years ago there was a service bulletin from Kubota put out about this plug blowing out. I will look and see if I have the updated part that bolted on to hold the plug in. The other option is to tap the block out and just thread a pipe plug in. Your tractor must be one of the early serial numbers.
3,181
1,602
It was PSB-1981-006:
