BX24 HST Leak?
2,579
Where is it leaking from? What does the dipstick say?
He has two videos linked (see the orange words).
It is overfull, leaking under the “middle” of the tractor.
I suggest he gets the level at least down to the max fill line and verify the vent is open. Then try to clean it with something that will remove the leaking oil. Then see if it is still leaking.
Add the UV dye and see where it is leaking from if you want to try that, but it seemed pretty obfuscated by the tractor wiring and the floor board.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
180
Attalla Alabama
mossycreekoutdoors.com
Thank you. I didn't realize the orange words were links. Good to know
9,896
It's probably leaking out the vents because you overfilled it.
And please quit calling it an HST service, it's not.
All you did was change hydraulic filter and fluid!
Very common for this vent line to go bad and leak.
Ngiovan
BX24, ZD326S
Dec 20, 2024
46
17
Pennsylvania
Finally got around to getting it back to level. Still has a leak, but has noticeably slowed.
Mentioned it to my local dealer when I stopped in for some mower parts and they printed the same picture that @North Idaho Wolfman posted and said it was likely the culprit.
I’ll look to address it the next rainy weekend. In the meantime, is there any concern with continuing to run the machine?
Finally getting some good weather and I’d hate to miss some hours in seat.
9,896
If the leak is really low, it could allow dirt or water to get into the hydraulic system, so I wouldn't wait to long to repair it.
Ngiovan
BX24, ZD326S
Dec 20, 2024
46
17
Pennsylvania
Jinxed it, rained all day today. I was able to dig into the leak a bit more and looks like it’s coming from the manifold. Read some posts from guys that just had to tighten things up, others had to replace the lines. Here’s a quick Video of me poking around.
9,896
Spray it all off with brake parts cleaner, then you should be able to pinpoint the leak better.
Ngiovan
BX24, ZD326S
Dec 20, 2024
46
17
Pennsylvania
Found the leaky fitting. After cleaning it up there was some o ring visibly blown out. I did snug the fitting up a touch which slowed the leak. Looks to be the line that articulates the bucket.
I’ll order up replacements tomorrow. Since I’m this far in, should I just replace all of the o rings in the manifold/controller? One other looked to have o ring blowout but no leak yet.
Ngiovan
BX24, ZD326S
Dec 20, 2024
46
17
Pennsylvania
Picked up the o rings this week, and finally getting into the tear down. Man, they really make you take a lot of stuff out just to get to these… i have half a mind to just cut out enough of the battery holder to access the fittings below.
Ngiovan
BX24, ZD326S
Dec 20, 2024
46
17
Pennsylvania
Made some progress. Another rainy week here in PA, so at least I’m not missing time on the tractor.
When removing the hard lines to the loader, one of them twisted while i was wrenching on it (pictured below).
Thought I’d do the right thing and get a genuine replacement from Kubota but the part that arrived looks awfully sloppy (top of the two lines pictured)
Any thoughts on if that’s enough clearance on the banjo bolt? Order up another? Stick with the original?
