Hydraulic Question
CSalemi
L3901 BH77
Mar 3, 2025
Tampa, FL
I’m getting a third function valve installed on my L3901 to allow me to get a grapple.
But it made me think about my BH77 backhoe.
There is only one line going to the backhoe, but I have two controls for the backhoe.
Does the backhoe have some sharing/diverter system built-in?
If so, why can’t the loader do the same?
torch
Jun 10, 2016
2,744
964
Muskoka, Ont.
It's built into the control valve set. The backhoe controls have internal passages to route the flow in the bank of spool valves according to the position(s) of the lever(s). As with the loader control.
However, you are adding an external control with it's own independent spool valve. There is no way to interface that spool valve directly with the bank in the existing FEL control. The additional control must be fed via the "Power Beyond" outlet on the FEL bank.
Now, it is certainly possible to design a FEL control bank with an additional spool valve for a grapple. And perhaps one is available via the aftermarket. But it costs more to add spools and Kubota has apparently opted to keep the base FEL price down. You pay more as a grapple consumer because you have to buy the kit if you add a grapple which is certainly more than the cost of adding another control to the existing bank at the factory. But those without a grapple pay a little less for the FEL alone.
Fedup
306
108
Winchester
The loader "can do the same". You can put as many valves as you want in series if use the power beyond concept. Many people have done it many times. You don't need electric valves.
2,056
To add a bit more to this, you can also stack valves together and they then share the hydraulic fluid from the pump so no extra hoses required. Those usually each have a lever that operates one valve at a time. But for some they arrange linkages so one handle can control all the valves (like the FEL)
5,260
The backhoe has two lines, one in and one out.
The third function will also have two hoses, one in amd one out.
5,260
Kubota is not keeping valve prices down. Just the opposite. This 3 spool loader valve sells for 1/5th the cost of a 2 spool Kubota valve.
CSalemi
L3901 BH77
Mar 3, 2025
Tampa, FL
Thanks for the good explanation
