Landscape Rake wheels
Bearcatrp
Mar 28, 2023
1,090
719
Minnesota
Old Machinist
May 27, 2024
567
674
NE FL
Good luck getting them. I bought a set from them when they were much less. The first set arrived with half the parts missing. The second set the box fell apart in route and never made it. The third set had parts sticking out of the box when it arrived but by some miracle all the parts were there.
Besides all that they are sitting in my barn somewhere not being used. I have as good a luck using the position control.
Oh, and the first two sets I had to have charged back against them because they wouldn't reply to any of my messages.
Bearcatrp
Mar 28, 2023
1,090
719
Minnesota
Care to sell them if your not using them?
Old Machinist
May 27, 2024
567
674
NE FL
No I might use or repurpose them some day.
I did modify the attachment when I rebuilt my landscape rake to make them connect further back from the rake.
Old Machinist
May 27, 2024
567
674
NE FL
This is how the package arrived on my third attempt to buy from them.
Bearcatrp
Mar 28, 2023
1,090
719
Minnesota
Ok. Here are the titan set I am looking at....
Just found these a little cheaper.
old and tired
1,919
1,297
Titan look like cheap wheels, more expensive. The Ignite wheels look more robust and are cheaper... I would still weld reinforcement gussets to either of them to make them better!!! Both look like they could break under normal usage.
Old Machinist
May 27, 2024
567
674
NE FL
The set I bought were from Pallet Forks dot com also. They were painted yellow back then. It's been several years so maybe they have improved their packing and shipping department. The rake wheels weren't the only problem I had with them. My first order from them was a pack of bucket teeth that were shipped with the wrong pins. They did not answer the phone or reply to messages so I had the charges reversed after a month of trying to get it resolved. They finally sent me a return shipping label two months after I had the charges reversed.
I did buy a backhoe thumb from them that arrived complete and on time so there's that.
Another thing to consider about adding wheels is you won't be able to reverse the rake with them installed. That may not matter to you?
Old Machinist
May 27, 2024
567
674
NE FL
That Tine Rake set attaches differently. They would not fit my rake. Make sure it looks compatible with your rake design.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
68
57
Lakes Region, NH
The Ignite wheels are identical to the set I bought from Atwood's but at a much better price than I paid. I have been very satisfied with the wheels.
Bearcatrp
Mar 28, 2023
1,090
719
Minnesota
Will probably order the tine set. Have to do some measuring before I order but should work. Cheapest I have found so far.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,158
3,422
Buy once, cry once. Those Ignite ones look like they will snap at the down tube pretty quickly.
Check out Homestead Implements. They weren't much more when I bought them. Better built.
bobnic
Mar 7, 2025
68
57
Lakes Region, NH
I've had no problem with mine which are identical to the Ignite ones. There really isn't a lot of stress on the down tube during operation. The highest bending moment is up at the attachment to the rake cross bar.
