LX2963 Snow blower not level from left to right
mrrlyoung
LX2610HSD, LA535 loader, BH77 backhoe, LX2963 snowblower
Jul 16, 2023
65
California
I just noticed when standing in front of our LX2963 snow blower on our LX2610 tractor that the blower is noticeably tilted a bit when off the ground. One side might be at least an inch and a half higher than the other. It levels off when you drop it to the ground, but we usually pick it up off the ground in use to avoid gravel. We were on a flat surface., and the tractor itself was level and not running.
Any hints at what to look at?
Dunslandloy
B2400HSD, 20 Kawasaki Teryx , Woods brush cutter, Befco tiller, Kodiak blade
Aug 4, 2017
59
SE OH
Drop your skids down on each side and this will allow it to float over the gravel while maintaining level ground contact. I do the same with my rear blade. 👍
mrrlyoung
Jul 16, 2023
65
California
I can try that, but it looks like something ain't right, and I'd like to correct it if I can.
RMS
Sep 26, 2021
283
624
Buckfield Maine
I've heard that having different tire pressures can affect this.
7,107
Actually check the rear tire pressures. Have more effect than the front tires.
Dunslandloy
Aug 4, 2017
59
SE OH
Are there slots where the carriage bolts attach the blower to the tractor? This would be your leveling adjustment.
RMS
Sep 26, 2021
283
624
Buckfield Maine
The k-connect frame under the tractor is solid with two pins that run from left to right that doesn't allow for any levelling type of movement. The only thing I can think of looking at my setup(same as the OP) is possibly not "catching " the blower with the subframe all the way on one side. When it is in place the two spring loaded pins are at the "in" position. Once there, the blower is solid to the subframe.
Mowbizz
Bx25d
Aug 19, 2021
567
328
My BX5455 is the same (when lifted). I never tried to straighten it out because it levels itself out when lowered. Haven’t noticed it as being problematic at all.
mrrlyoung
Jul 16, 2023
65
California
Thanks. Our ground is so gravelly (think sandy) that shoes or skids too easily dig in and we start throwing rocks. So we pretty much have to pick it up a bit and not use float. It gets the job done. I do wonder about trying some of the HUGE skid shoes I've seen. I think all is attached properly and I think there isn't any way to make an adjustment, so fingers are crossed that it's a tire pressure issue. I've see where people have put a slit pipe over the lower edge for gravel, but I haven't gone there yet in my own mind.
Donystoy
Dec 10, 2013
693
329
Binbrook, Ontario
You can also run a tape measure along either side of the front of the tractor vertically in the area where the "K" connect fastens to the front frame to see if there is any difference. Maybe something has shifted. I have the identical set up with no noticeable tilt.
unhdsm
B7500
Jan 9, 2024
12
Bradford, VT
My BX5455 is off about an inch. Never been an issue.
