T M G products. Does anyone have experience with them.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
I am looking at their ditch bank flail mowers. I know they are a cheaper brand and not up to woods or landpride quality. But am wondering if they are junk, or just a lighter duty machine. No heavy work, just heavy grass on road edges, and pruning my woods roads back in the 90" degree position. Nothing over 1/4 inch diameter and more like 1/8 for stems being cut.
Thanks.
8,810
There are a lot of forces on the various components of a ditch bank flail mower, and the chances that a Chinese knock off consortium such as TMG gets it right is basically zero. For example, I bet the attachment point for the cylinder that rotates the cutting head will flail in short order. Take a look at a quality flail and you'll see that the steel is thicker, and it's reinforced to handle the forces exerted on the mounting point. In addition, the box/cowling/shield or whatever you want to call it is reinforced on the better models.
TMG is another VEVOR vendor variant selling knock off products of quality implements designed by companies who actually spend money on testing and development. Would you have a positive ownership experience spending 50% of what you'll pay for a BEFCO, Del Morino, Land Pride or similar? Only you will be able to answer that question.
I have a Del Morino ditch bank flail and the $5k I paid for it was soon forgotten. I use it more often than the other two rotary cutters and it's even made me money on two jobs and no doubt will make me more money this summer. Everything on that Del Morino is well engineered and well made, and the only issues I've had over the past three seasons have been down to abuse on my part i.e. running over large heavy objects hidden in tall grass or weeds. I've had to repair the front guards twice now, but I made a modification to the guard system so that I can abuse the flail in the future without having to spend time fixing stuff.
I completely understand the cost vs. performance vs. longevity decision matrix process and it's everywhere in life. Sometimes I think about buying a cheaper variant with the idea that I can address the shortcomings if necessary. Had I bought a Chinesium flail I would for sure be looking at ways to reinforce the mounting points that are subjected to considerable stesses.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
I just ordered the 60 inch Mechmaxx ditch bank mower that's probably about the same. Was cheap and only need it a couple times a year so I took a chance. Ordered their stump grinder 2 weeks ago and it's not bad. I figure if it lasts a year under warranty, it should be good for a couple years. Will have it next week hopefully. Biggest issue I saw on videos that I watched was the pto shaft can hit the frame on some tractors when fully offset (seemed to be 3 point arm length related) . It's 650 pounds and looks to be well made but only is good for up to 1 1/2 diameter bushes unlike the DelMarino I looked at that was good for 2 inches but 3x the price. Only comes with hammers.
Moose7060
Oct 14, 2023
827
2,242
bc
I have no first hand knowledge of TMG equipment because everyone warned me not to waste my money.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
It looks like a few companies sell pretty much the same ones. Mine will only cut tall grass and twigs, so I think it would probably survive. Plus one afternoon a year would probably do all I need to do.
Thanks
8,810
I run the Del Morino 62" flail on the MX6000 and the tractor handles it well but I have liquid ballast and wheel weights. The Del Morino is supposedly 820lb and the cutting head when fully extended puts a lot of weight off to one side of the tractor. If the MechMaxx 60" flail is really 650lb I wonder how your Kioti will handle all of that weight being offset.
I hope you don't have any need for the warranty since it's just about worthless with these Chinese conglomerates like VEVOR, MechMaxx and others.
For anyone buying a cheap Chinese knock off, particularly the ditch bank models, I suggest you keep an eye on the bracket and welds where the cylinder for cutting head rotation attaches. There's a lot of force on that mounting point and it's just not engineered well. Compare the Del Morino bottom to the MechMaxx top.
Here's how Del Morino does it.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
My tractor is a little over 5000 pounds with filled tires, cab, and loader. Many run the 65 inch on the 35 hp Kioti version that's the same weight as mine without problems. The lighter DelMarino offset flails for 25 hp machines are about identical weight. I'm not worried about welds as it won’t see much use plus I have a big welder and cnc plasma table for mods. $2400 versus $6800 was the decision maker for me. Actually I find the Chinese respond to warranty claims quickly and they are made side by side on the same lines as some of the nane brand assembled in the USA products made with offshore parts.
8,810
I get it. It's hard to justify spending a lot of money on something that isn't used much, and that cost difference is substantial. After a few more jobs this summer the Del Morino will have brought in more money than was paid out for it, but it's going to take a lot more summers before I can say the same for the RC3712. 😂
I don't buy an implement with the idea that I need to do work in order to pay it off, but if that's an option then I feel even better about the investment. I know people who pay $1,500 or more for snow removal each winter. I've never paid for snow removal, but it didn't take more than a few winters before I was at the break even point based on the cost of the front blade and blower. But it's the convenience and independance of doing one's own snow removal that appeals to me more than the need to "pay off" equipment in my head. The latter is just icing on the cake.
I look forward to hearing all about your flail and how it works for you. I hadn't realized that your tractor was such a beast, but it sounds like you're more than prepared to run the flail, and to make any needed repairs.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
The one thing I forgot to mention is the Chinese flails all come with cheap molded hammers that do not last as long as forged flails on the DelMarino. It appears the molded ones last about 3 years without major rock contact. I plan on buying a replacement set of forged hammers and swap them in as the original ones are damaged. I don't mind using the cheap ones as rock finders anyway.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
It arrived today in good condition with no damage. Looks well made and the welds are beautiful Single digit wind chills and snow for unloading. Just like February today. Guess I won't be using it for a while. 750 pound shipping weight. Fedex freight is the best in our area, they never damage a shipment.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
View attachment 152097 View attachment 152098
excellent.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Woodland mills had a big sale, so I bought their 28" stump grinder. So the flail is on hold for now.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
Well looked good on the outside but lots of burried damage from poor packing. Hose damaged, cylinder damaged, paint damaged and no number to call. Waiting for an email response but going to need a lot of parts and paint. Just changed my mind about MechMaxx.
  • Sad
Sidekick
Jul 29, 2023
998
1,336
N.Y,
I made a video to show them the damage. Really needs to be replaced and I hope they take care of it.
  • Sad
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
256
166
WNY
You might want to try emaiing Lucas Peek, he is on you tube and has helped others get in touch with Mechmaxx
Sidekick
Jul 29, 2023
998
1,336
N.Y,
You might want to try emaiing Lucus Peek, he is on you tube and has helped others get in touch with Mechmaxx
I'm going to give them a chance to respond first. I think they will stand behind this after looking at the video. Just stinks there's no phone support for fast support. Hopefully will know in a day or 2. I hope they will replace it but always have PayPal for help in the end.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
I just emailed Lucas because of no response from MechMaxx. Only offshore support and he is going to pass my information on to them. On a Kioti form another had similar issues plus missing parts and was told live with it and find parts locally so it seems like poor support and bad packaging.
Orange man
Jul 23, 2014
256
166
WNY
Hope they come through for you, I looked at a "new" box blade today, all dented and rusting and the dealer said oh well... still the same price. And it was a landpride.
Sidekick
Jul 29, 2023
998
1,336
N.Y,
Still nothing. Found a supposed support number and called it. Puts you on hold and never goes further, tried emails with no response, tried the chat and the minute you type looking for support it stops replying, they remove reviews from their site, youtubeers that get products for free and always do good reviews can't help. Looks like I'll try filing a complaint on PayPal tomorrow if no responses. They are a drop ship company in China and have no support I am finding. I hope 3000% tariffs get put on their products so they don't tempt people to give them a try. I learned a lesson this time.
