l2501 Box Blade Poll
What size Box Blade do you use on your L2501 or L2502?
  • Total voters
    17
dkforge
L2501DT, BX2670 - (loader, MMM, snowblower)
May 10, 2014
9
North Central, PA, USA
So I just had my L2501DT delivered and am looking at box blades. I've read every thread I can find in trying to decide between a 5' and 6' box blade. I think a 66" would be ideal based on the tractor with R1's being 66" but trying to find a 66" is proving challenging. So here is a poll to let me know what size you are using on your L2501 or L2502. Maybe it will help me decide.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,784
2,221
Western MT
I use a grader/scraper, but I voted 6’. That’s my gs size.
ken erickson
Nov 21, 2010
1,334
2,372
Waupaca Wisconsin
I cast my vote for a 4 footer. However the ONLY reason I am using a 4 foot is that I had previously purchased it for my B7100. My soil is sandy , very little clay , and I have about over 1/2 mile of gravel road. I have used it now for 4 years , dug two ponds, cut trails and maintained the driveway with no damage but I tend to be a operator that does not push my equipment to the extremes.
IF I was going to buy one for my L2501 I would opt for a 5 footer.
Including a picture of what a 4 footer looks like on my L2501, R4's with no wheel spacers.
old and tired
1,919
1,297
My L2800 with R4 would be comparable to L2502 with R1/Ag tires... I used the 6 footer to build a road down to our creek. Working down hill was fine, heading uphill I would have to grab a bucket full of dirt to get better traction going up hill (and still not be aggressive heading up hill).
I've flatten some side hills to make flat camper spots. The extra weight of a 6 footer helps a lot to cut through fresh sod.
You could be able to stop that L2501 with almost any of the sizes, if it's adjusted aggressively enough. So, I don't get overly aggressive setting of the top link.
ayak
L3301 HST
Feb 16, 2018
731
1,086
WV
I started with a 5’ but later decided to move to a 6’ once I got my rear spacers on.
forky
Feb 23, 2021
328
364
Wisconsin
My dealer set me up with the land pride BB66" . It covers my R1 tracks and is no
problem at all. I think it is the perfect size for my set up. With loaded tires it is
also, the perfect ballast for the max lift abilities of the 2501.
bbxlr8
Mar 29, 2021
446
308
Eastern PA
60" basic one is the goldilocks one for me (with R14s).
My use case may be different than most - FWIW I tried to get by w/o & found that I totally NEEDED it for basic shaping and leveling for difficult soil w a lot of rock.
nerwin
Nov 13, 2024
603
1,625
Vermont
youtube.com
Surprised to see 6 footer most popular. I think this really depends on what you are doing with it and the location you are at. Where I live we get frost, it was under an ice age so rocks and rock and more rocks is what you get when you dig stuff up. Clay is another issue as well, I have a lot of it on my property and stuff is sticky. So sometimes I feel like bigger isn't always better. I believe the most important part at minimal is to cover your track width and that's why I feel like the 66" box blades are the ideal size for the "small" L series. The large frame L series like the 4000 model a 72" would be better, perhaps bigger.
But it really depends on what you're doing. Just pulling really light pea gravel stuff then you can get away with a 6 footer or maybe a 7 footer but the more material in the box, the more weight the tractor has to pull and eventually just going to stop it in its track.
I'm still a newbie so I'm learning...take what I say with a grain of salt haha,
ayak
L3301 HST
Feb 16, 2018
731
1,086
WV
For me it comes down to covering my (spaced) R4 tracks and making sure I can at least have the option to head downhill, if needed—and there are plenty of hills, rocks, and clay to contend with here.
ayak
L3301 HST
Feb 16, 2018
731
1,086
WV
With no material in the box, the 5’ box blade I had came in at 345# whereas the 6’ version weighs 510# empty—FWIW
forky
Feb 23, 2021
328
364
Wisconsin
Just to add the BB66" weight is #370.
forky
Feb 23, 2021
328
364
Wisconsin
Depends which one....because the BB1566 is 450lbs. The BB1572 is 504lbs.
The BB2566 is 500lbs and the BB2572 is 550lbs.
Yep nerwin, I was referring to the BB1266. I've used it alot and have no bent anything.
nerwin
Nov 13, 2024
603
1,625
Vermont
youtube.com
I just hate the clips for the ripper teeth...I like how they are implemented on the 15 series. Plus its heavier better for ground engagement.
OntheRidge
Nov 1, 2020
455
534
Maybe take a look at Homestead Implements. I had their 72" Pinnacle series BB behind my L2501, pulled it with no problem unless I let it get full. Very good quality build.
biketopia
Feb 15, 2024
388
398
Warrenton VA
https://www.ruralking.com/rk-by-king-kutter-5-box-blade-with-5-shanks-red-bb-60-rr
The 60" "Rural King" branded king kutter I picked up 3 years ago is 475lbs. I also only paid about $600 for it then. I've stopped my tractor from getting too greedy. In my opinion, the width should always cover the rear wheels on a CUT, then it's up to the operator to play with the attack angle and depth to keep from stopping forward movement. Top and Tilt is really, really handy when working with a box blade to shape land, cut a road, etc.
Larger, heavier tractors can go substantially wider because they have the weight and power to pull them.
NvRudder
L2501DT, LA525, R14's, Bison NVHA210 84" RB, Allied 60" SB, Diamond C 10k Dump
Jun 15, 2021
86
102
Northern NV
Have a 7' Rear blade vs Box Blade for my 2501DT
Let's me cut/maintain small irrigation ditching across the pasture...
Do have to go slow in case the end of the blade catches a rock and could pitch the tractor...
I don't have loaded tires...
forky
Feb 23, 2021
328
364
Wisconsin
Good point about the clips, however the correct tool always in the tool- box
makes it a non- issue in my case. It would be a pain if it was more rippers to
deal with.
