Anyone have a Ripper for sale?
MOlivin
L6060
May 15, 2023
52
MO
Hi all,
Been looking for a Ripper for a BH92, but their all a small fortune just for this little hook.
Does anyone have a used one for sale? I'm just using it to cut through rocky clay ground to put electrical in, instead of using the 16" bucket making a mess.
Thanks all!
ayak
L3301 HST
Feb 16, 2018
708
1,017
WV
Will one for a BH77 work?
MOlivin
L6060
May 15, 2023
52
MO
I'm not sure, do you have a make/model of the ripper? I can call the manuf. and find out.
5,181
Hi all,
Thanks all!
A ripper is an amazing tool.
A company in Georgia makes great custom rippers,.......OX Thumbs.com
I bought a ripper ( 28" depth -new ) from them last year for my L48 TLB.
Kinda pricy at $1,000 delivered, and likely a bit larger (deeper) than you could use.
Checkout their website! -oxthumbs.com
Might also be worth a phone call......770-862-4653
MOlivin
L6060
May 15, 2023
52
MO
BX said their ripper will not work on a BH92. DAMN!
I was originally looking at MIE's ripper because of the 7" back plate on it, but it's right up there at $1200 with shipping.
I've not heard of the OXThumbs, I'll take a look and see what they got.
Thanks!
John T
2017 BX23S
May 5, 2017
1,065
534
under a rock
Take a 4' long piece of 3/16" or heavier angle iron and CHAIN it to the front of your bucket.... (vertical) leave enough on the bottom to go as deep as you want.
lower the bucket and put the tractor on 4wd turtle speed and drag it in reverse.....
poor mans ripper.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
If your ground wasn't rocky -clay, you could ruin your chain saw blade and bar...
Or use a pressure washer...
Rocks can be a hassle, but in my experience clay is worse. THE worst. A BH ripper sounds like the best way but it's going to be a rockem'
shakem' fun ride on you and you BH.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
poor mans ripper.
Right on. I was thinking something similar. But his ground is clay... and rocks. He needs a BH ripper and patience.
EDIT: Or a Cat D6 or similar with one ripper. Or a herd of young laborers with pick axes and shovels.
notforhire
Kubota L47
Dec 5, 2019
148
69
Meadows of Dan VA.
Is yours a pin on, or do you have a QA bucket?
MOlivin
L6060
May 15, 2023
52
MO
Last Fall I dug 1500' 3.5' deep 18"w for a main electrical line in it... and just did another 100' at 8' deep for drain lines... it takes a bit, but it works. It's great when you hit a rock thats about 2' big.
Dug a 1.5'd ditch down a hillside 1200' long last month, all wash good until I hit a rock plate in one spot. Went 3' down, left of the ditch about 1' and right of the ditch about 2.5'. That one was the hard one.
MOlivin
L6060
May 15, 2023
52
MO
What does "small fortune" mean in your mind? I'd suggest making your own but you might think that's too expensive as well...
$1200 is average for one of these with shipping... a small fortune for a little hook.
3,932
2,583
Fabbing the parts is cheap enough so long as your time and machine time is "free"
5,181
Yup,......"a small fortune for a little hook"
But,......It is something if needed, has no peer.
Mine weighs about 125 lb.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
With a chain saw? Or a pressure washer?
8' deep? Or did you mean 8"?
8 Feet deep requires shoring.
Sorry, i am easily confused online.... it is all without voice inflection.
Thanks.
Be well. Tractor on.
MOlivin
L6060
May 15, 2023
52
MO
Thanks.
8'.... no shoring needed, dug... piped... backfilled, done.
