Where to find a service manual for a B2650
Jsjac
B2650
Feb 13, 2022
215
335
I looked on the Internet for a service manual and could not find it.
Maybe my Google fue is not working to good today.
Any suggestions were to find it.
Went out early this morning to move my log splitter when the lawn was frozen. Had a hard time getting the tractor started. I assumed the glow plugs were not working. I got it going but took a lot of cranking.
Not sure where to look for the glow plug fuse and relay
9,283
Look at the top right of your screen at the envelope. 😉
Jsjac
B2650
Feb 13, 2022
215
335
Thank you again for your help with this.
I figured out the the Female connector the the relay push into were loose. The large pins that carry the heavy current load. Tighten them up and it works again.
I might change it to a better setup with a more robust connection than Kubota used. Looks like a cheap relay to me.
jfcrlsn
M6800
Jun 8, 2020
MN
Would you happen to have one for the M6800? I thought I had one downloaded but it's only the hydraulic shuttle supplement, not the manual for the tractor.
would you be able to a copy of the M6800 service manual as well? The one I have is not very comprehensive. Thank you
9,283
What's the max file size?
I tried to open a conversation and attach the WSM pdf for jfcrisn's M6800 and it said the file was too big. 14.8MB. Or am I doing it wrong?
Looks like Fedup needs on too.
I use a server site to hold all my manuals, then I send links to share them.
You can't easily directly mail all of the manuals as they are just too big.
Fedup has the manual as I sent it to him. ;)
