hyd.line
still running
1989 -B8200 hst 4 wheel drive
Mar 21, 2025
New Castle,Pa.
i purchase a B8200 hst 4x4 with front loader BF300 going to buy some hose for the bf300 loader getting dry rotted wondering the size 3/8 or 1/2 my neighbor has a crimper and i will need the ends. you go on line every one wants a # number for the hyd, hose looking for the four hyd. hose from the lever [controls bucket] to the fitting thinking hard pipe all so there are two more lines at control lever and they go to a hook up buy your right foot their like 5 foot long all ways in the way and getting caught when you raise or lower bucket. if i had hose size or part numbers save me some time.
Hugo Habicht
G1900
Jun 24, 2024
1,015
1,459
Ireland
Hi,
I cannot answer your size question but can you not reuse the old ends? If your neighbour has a crimper / press it is likely that he has the ferrules too. If you cut those open (carefully, not to damage the fitting inside the hose) that is the only new part you will need, plus the hose, of course.
Kennyd4110
Vendor Member
Sep 7, 2013
1,419
746
Westminster, MD
www.boltonhooks.com
Hi,
Hose ends are not reused on hydraulic assemblies.
Donystoy
Dec 10, 2013
690
324
Binbrook, Ontario
On my b7200 that was about the same size, the bucket curl used 1/4" hoses and the loader lift used 3/8". Easiest to take old hoses to a hydraulic shop and have new ones made up.
5,978
3/8" (#6) hose. I would suggest R16 as it is much more flexible than R2. This is good hose and competitevely priced.
