Is a quick hitch worth it when you have adjustable links
10,108
Boy is this sweet with attachments that are made for it. Got the stump grinder yesterday and took 15 seconds to hook it up. Still need to get off for the pto, but that slips in easily. I like how the top link has multiple holes so the implement matches my other attachments. Top link is supposed to be here Wed. Definitely worth it in the end after a couple surprises.
You'll like it even more once that hydraulic top link shows up! You'll be able to angle the top hook and pick up an implement in seconds. When picking up an implement, you can leave the locking handles down if the implement has enough weight, which means that you don't have to get out of the cab to engage the locks i.e. don't need to put the locking handles down.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
I can't wait to try the toplink. Wound up getting it for $127.00 after discounts and points when the new stock arrived. Hope it works good being so cheap with hoses and qiuck connects. The stump grinder pto needs to be set to 17 degree universal angles so have to come up with some kind of gauge for repeatability.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
Well it finally arrived and looks really nice. Cold is back so going to wait until next week to try it. Looks really nice and came with decent looking Chinesium hoses. Hopefully it swaps right in.
Shadetree605
kubota b2100
May 1, 2022
231
117
north little rock, ar
i don't have hydro tilt on my b2100, but i did purchase a landpride qh cat 1 for it, night and day difference in hooking up attachments, but man...it sure as heck wasn't cheap !..lol.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
Top link fit on with a little grinding. Bushing was a little wide for the mount so had to grind about 1/16" off it. No leaks and works. If I try to extend it full speed it's a little jumpy. Go slow and it's smooth so seems like the lock doesn't like fast. Mounted it with the lock block down then looped the hoses over the top that keeps them easy to plug and out of the way. I'm happy so far, wish it would dry out enough so I can try it. More rain and snow on the way 😬.
Shadetree605
kubota b2100
May 1, 2022
231
117
View attachment 151798 View attachment 151799
would it have been better to mount the top link cylinder where the lines/fittings would be on the top instead of the bottom ?, this way it would give you more room for the lines.
2,577
There are orifice fittings that help control the speed of the movement. Looks like you would need to install at the tractor end between the hose and the coupler.
Here is a link to a vendor member site for examples
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
I tried that first and found the hoses hard to plug in plus the lock block was vulnerable. This works best for me but it is easy to flip also.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
Thanks, I will look into them. Mine has straight threads and copper gaskets so I'll have to find what thread I need. It's definitely to fast if I don't just feather the valve.
2,577
That copper gasket USUALLY indicates the BSPP threads (also known as DIN G threads). They will be sized in fractions of an inch and by a dash number. This chart should help you determine if that is what you’re dealing with. Just note the male thread diameter is NOT the size!
2,577
From what I could find it's something called G 1/2 on the quick connect end of the hose.
Are you wanting to install them directly into the valve body (between the vale and coupler half) or on the hose (between the hose end and the coupler half)? I guess either would work but if attached to the valve body they would be in anything’s circuit that is attached to the couplers. If on the hoses then they get removed when you disconnect the top link.
And I know that 2 we’re supplied with my top link, so one on each hose.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
I really don't know. Was thinking between the hose and quick connects. Other option I am thinking about is if I can find another set of those hollow bolts and copper gaskets that attach the hose to the lock block, maybe I could weld one of the holes and see if just one cross hole would slow it some. Would be nice if those bolts were available with smaller holes. For now it will stay as it it is because to many other things to do as we thaw out.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
535
218
CNY
G 1/2 is another term for 1/2 BSPP as PF is the same as well.
An easy way to put a restrictor in the circuit ids to tap the ID of the banjo bolts and install a plug with an orifice. I like to use brass set screws.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
Thanks, that is a great idea.
Sidekick
Jul 29, 2023
1,132
1,604
N.Y,
Made a video while installing it
