IP pump failure
rmcphearson
Golf Course Tractors and Vehicles
Mar 16, 2025
9
San Jose, CA
Hi everyone,
Newbie here with a question. My dealer is trying to get out of a warranty repair by telling me only two things can seize an IP: gas or water. I don’t think either happened to my D1105. I think the pick up (electric) pump may have quit (a common problem with my vehicles) and the lack of fuel when the operator cranked the engine for several minutes may have damaged the pump. Your thoughts are appreciated.
Thanks,
Roland
10,622
Hi everyone,
Thanks,
Roland
I think someone is feeding you a line.
But your going to have to give more details to get better answers.
What is the damage to the IP?
I've never seen one damaged from simply cranking an engine.
3,522
1,951
This style of injection pump can not pump itself dry, there should be enough fuel in it for lubrication.
As North Idaho Wolfman stated, there are a lot of details missing.
5,506
2,219
get a fuel sample from your RTV and send it out for analysis. If they find much water and/or gas in it, your question has been answered.
was a somewhat common issue for a few years. They aren't exactly wrong, especially water.
rmcphearson
Mar 16, 2025
9
San Jose, CA
The IP was pumping only air, no fuel. The dealer says “the pump seized and their are only two things that will cause it to seize: gas or water.”
I don’t think the IP pump ever “seized”. I think I have them on a technicality on that. If it seized then it wouldn’t be pumping air, correct? And could the engine turn over normally if the pump was seized? Yes, I’m splitting hairs here, but I have good reason to play hardball with them. More details on that later.
I’m not satisfied any gas was In the fuel. It never ran rough or smoked like the several other D1105s I’ve witnessed in years past that had a significant amount of gas in them. I’ve seen D1105s run very rough on mostly gas and smoke the whole neighborhood and never damage a IP. I didn’t smell any gas in the tank before the dealer picked this one up.
They are not going to give me a sample of the fuel. I wouldn’t trust anything they give me. I’ve caught them flat out lying to me before.
The only thing I’m confident of is that the IP failed.
Thank you for the help so far.
10,622
Little confused as Injection pumps don't really pump air.
Either they pump fuel or they don't.
If it was seized it would have to be seized with the pump or pumps collapsed.
That could happen, but super rare.
There will be physical damage to the pump if it seized.
John T
2017 BX23S
May 5, 2017
1,239
769
under a rock
I can understand water in the fuel ... sitting for a long time creating rust ... or gunked up fuel.
Gas? why would they even mention that... It's has to be a rarity that some bonehead dumps gasoline into a diesel tractor....
personally I'd be offended if they suggested that to me.
Anyway, If you take it off yourself make sure you do some research or ask around.
Not sure what the pump is or the tractor for that matter... But most injection pumps need to be timed properly.
check to see if there is a Lock pin. If it's a quality pump shop they will make sure that pin is exactly where you set it... when it comes back.
just don't turn over the engine when the pumps out...
again... I don't know if all this will apply to your situation but worth looking into.
rmcphearson
Mar 16, 2025
9
San Jose, CA
More detail: the first symptom was that it was very hard to start in the mornings when cold. After cranking for several minutes it fired up and ran great after the engine warmed up. It would fire up again immediately when the engine was warm. This happened for several days. One morning it would not fire up, dealer tech came out and decided to haul it away.
The line “the IP seized” doesn’t make sense to me. The symptoms were intermittent. A seized IP would not cause hard starting and then decide to start working fine. That's my opinion.
They already installed a used IP. They are holding the vehicle hostage until we pay $1200. I'm trying to get my guy on the inside to get the old pump to me so I can look at it try to figure out what really happened, and also just to learn more about IPs.
Also, I noticed in my records this vehicle ran rough occasionally over the past 3 years. I made the dealer aware of it. They never figured that out.
rmcphearson
Mar 16, 2025
9
San Jose, CA
I've been told by a friend who maintained a diesel fleet that the first thing that came to his mind was if the IP chugs air while the engine is running the seals can degrade quickly. I'm buying that.
10,622
Yea but Kubota pumps don't have seals to degrade.
They are steel to steel seal.
Hard starts are rarely IP they are normally glow plugs or compression.
If it's pulling air into the fuel system, it can cause hard starts, but that's normally easy to figure out.
5,506
2,219
sometimes the plungers will stick in the "up" position. I've seen this a couple times. When you "crack" a line loose, it'll just act like it's bubbling and not much more. Only way to know is to pull the pump out and on some engines you can remove the inspection cover and look at the rollers. If they are not in contact with the cam, the plungers is stuck.
as far as getting gasoline in the fuel tank of a diesel fuel powered equipment? It happens a lot more frequently than one would think. Other way around too (diesel fuel in a gasoline powered equipment's fuel tank). I just went through this on a Polaris last week. Thankfully the owner used red fuel so it made it a lot easier to diagnose. As luck would have it, another one showed up today but with road diesel, so it made it considerably harder to diagnose as it's exactly the same color as diesel. Wasn't much diesel in the fuel but enough to cause problems, being that these things is fuel injected, and the injector pulsewidth is 1.1 to 1.3ms (very very little fuel is used at idle and startup).
rmcphearson
Mar 16, 2025
9
San Jose, CA
Hello all, I have an update. After getting the runaround from the dealer and demanding to know if they sent the IP out for independent testing this is what happened...
Dealer finally sent the IP to a diesel repair shop (DD). DD concluded there was water in the crankcase, which rusted the plungers and cylinders on the engine side. The rollers/tappets were also worn prematurely due to lack of lube. They found no indication of gas in the fuel. I got my hands on the pump and can see now exactly what they are talking about.
The engine oil was sludgy. Dealer sent it out for testing which showed there is glycol in the oil.
The dealer has increased our bill to cover what they paid to have those 2 tests done. So, they are now charging us $1500 instead of $1200. They have not said a word to me about how water got in the crankcase. This vehicle is still under warranty.
And yes, these are some dirty, incompetent mother fuckers.
rmcphearson
Mar 16, 2025
9
San Jose, CA
It’s in a HDX utility vehicle.
The dealer is now refuting the report by DD. The dealer is now lecturing me that the failure was due to water in the fuel and “it’s impossible that the DD report is correct”
3,522
1,951
With the engine under warranty, who authorized the dealer to install a used injection pump? Kubota sure didn't.
You can not be charged for repairs or parts you did not consent to.
If there is, in fact, antifreeze in the engine oil, there are only 2 ways it got there. Someone poured in or the cylinder head or gasket has a seep.
rmcphearson
Mar 16, 2025
9
San Jose, CA
Great points, I didn't think about that angle of the story! When we contact Toro and/or Kubota we will inform them we did not authorize the used pump, and we did not officially authorize the repair.
Hugo Habicht
G1900
Jun 24, 2024
1,493
2,144
Ireland
They have not said a word to me about how water got in the crankcase. This vehicle is still under warranty..
Doesn't really matter to you how the water got into the crankcase. This is for the dealer to find out and repair under warranty. The injection pump seems only a follow on problem from the coolant leak.
rmcphearson
Mar 16, 2025
9
San Jose, CA
I agree. They are currently refuting the diesel repair shop and the oil test (done by two different entities). They are telling me that there must have been water in the fuel and asking me "how often do you change your fuel filters". In other words trying to blame me again.
These are some low down dirty mother fuckers.
