Well today I got my roof top ac heat unit delivered to my farm. I hooked the positive wire right onto the alternator and ground to the block. I set the unit up in its box and started the tractor and the ac unit. I let it run for one hour at 1400 rpm’s. The ac unit has a voltage setting which shows the current level and you can set a level between 9 and 11.5 volts to stop the unit if voltage drops that far. I checked the voltage every 10 minutes, the temperature of the battery and cables and all was cool and normal. The voltage on the unit was 13.9 to 14.1 the entire hour and the air was very cool coming from the unit. I would say it was a successful test and now to order my cab.
