B7100 Head Gasket
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
New Member, I acquired a B7100HST D that I'm pretty sure the head gasket had a leak or the head was cracked. I had white smoke constantly and I couldn't keep it from overheating after 5 to 10 minutes of running. I removed the cylinder head and the head gasket laminated in shreds, some sticking to the head some sticking to the top of the crankcase. I couldn't tell where any leaks may have been happening. I cleaned the head and clamped a plate with a gasket on the bottom (Cylinder side) of the head, I then filled the head with water and let it set for a few days with no apparent leaks, I then machined a plate for over the discharge area and fit an air hose on it to pressure test it, I did get some leaks but, they seemed to be coming from my gasket setup, I had no visible water in the intake or exhaust areas. Concluding I believe that the head is not cracked.
Looking for some confirmation that I have checked this well enough to rebuild.
When I went to clean the head gasket from the top of the crankcase, I noticed a small soft rubber flat ring gasket around the pin pipe (Ref No. 110) that sticks up from the cylinder housing. I'm thinking the was the o-ring Ref No 140 Part Nu 15221-33700. not sure.
Any advice would be appreciated. Thanks
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
121
95
Northern Idaho
One thing I have seen in other engines is a crack around a guide or under valve seat that only leaks when engine is hot. Barring that, I’d check block and head for flatness and if good, and head leak check is confirmed good, I’d put it back together and see. Did you happen to run a compression test before you tore it down? Low on two adjacent cylinders is a definite blown head gasket.
8,591
Take a good picture of the head showing the valves and prechamber.
3 pictures.
I can spot the leaks every time.
Get An OEM head gasket, NO aftermarket head gasket!
Head gasket: 15371-03312
O-ring: 15221-33700 (some Head gasket sets come with the O-ring)
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Unfortunately, I did not do a compression check. Hindsight I guess I should have. I just jumped right in and took it apart. I imagine I could check it after I re-install the head and torque it, right? if it is cracked around the guides would the compression check verify it that it is or isn't cracked? I know the gasket would be out of the equation then. I will check the flatness on Monday, I want to inspect it on a surface plate and run an indicator under it. Does a warped head indicate a crack or just the source of a head gasket leak. Flatness should be less than .002 correct?
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
3 pictures.
8,591
The right is the only one I Question?
If it is a crack that is not typically how they crack.
Take some brake parts cleaner and get the oil / antifreeze off of it then take another pic if you would.
If you pull those two valves out, if it is cracked you'll see it in the seats of the valves too.
6,471
You might be able to take the head to a machine shop and have them magnaflux it for another opinion.
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
I guess I was trying to be cheap, but that never pays, and I know that, I should just do it right and completely strip it and get it mag checked, then I'll know for sure.
8,591
Just strip it and post another picture and I'll give you a better answer.
I am only slightly sure on that one, the others are good.
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Can I reuse the valve guides if I remove them? Do they need to be pressed out?
Or just leave them in and check it after taking out the valves and cleaning it up?
8,591
No you won't remove the valve guides to check it, just the valves themself.
Keep the springs, valve caps and keepers matched to each valve.
Really just a good clean up with brake parts cleaner might show me that spot better.
8,591
One other trick is take the picture in as high of resolution as possible.
I have software to blow the pictures up and see great detail.
If for some reason you can't upload the picture here I'll give you an email address or Phone number to send it to.
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Ok
Thanks, I’ll not be able to get to this until the weekend
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Well I finally got a chance to work on the head, here are my pictures.
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Another interesting thing I noticed is that the combustion chamber is raised about .010 above the head on all three cylinders, is this common or should it be flush to below the head surface?
WilGan
Kubota B7100HST D
Mar 8, 2025
11
Vernon, CT
Seems to me that that would/could cause the head gasket to not seal properly in that area
8,591
Heads not cracked, and the prechambers plugs being a little raised is very normal and doesn't hurt it on bit.
Lap the valves and run it.
