How does this cylinder piston damage happen?
Shawnba67
23
9
S.E. IN
So how on Earth can this backhoe swing cylinder get damaged in this way?
I tore it down to reseal for a leak and well more $$$ needed. Lol
The parts manual shows a bushing in the threaded end piece (gland?), does anyone know if I can replace that or does it get reamed to final dimensions after install or such?
10,979
It would really help if you told us what this cylinder fit.
It looks like the end of the piston broke and blew out but there may be more involved.
10,979
M59 BH boom cylinder right?
That's a very Unique cylinder!
It looks like the control end is broken off.
I do believe the control end keeps the piston from slamming into the bottom of the cylinder.
And that part probably caused the break in the piston.
Did it blow a hydraulic line under use?
It looks like you will have to replace the entire cylinder, because I'll bet there is damage inside the piston bore.
Shawnba67
23
9
S.E. IN
Well I ordered a new piston and once it arrived I tore cylinder back down. The piston had witness marks from retention nut on both sides! On further examination the piston was installed backwards. In the pic the "nose" on the bottom has a pocket it goes into at rear of cylinder. So everytime you'd swing full travel it would get bashed on. Mystery solved.
