Rear Hydraulics
10,251
So presumably the joystick buttons are maimtained. Whats the advantage of having the switches on the joystick over the switch box?
The buttons are momentary i.e. hold a button down and move the lever to move the piston. I opted for four momentary switches in the diamond pattern since this makes the most sense to me and my intended use. I chose not to have the optional trigger on the front of the grip. Here's a photo of the control grip that I bought.
10,251
Thats a two hand operation? Right on the joystick button and left operating the remote.?
One hand (see photo above). Hold a button down as you move the remote lever forward or backwards.
10,251
I guess I misunderstood. I thought the handlecwas hoing on the loader joystick. You are putting the handle on the remote valve lever?
Yes. On the remote lever.
My specific application is for a Buhler/Farm King rear hydraulic blade. It currently has three cylinders for boom, angle and tilt. I want to add a fourth cylinder for gauge wheels (that I'll fabricate). The idea of the four button control grip is that I can control all four cylinders from the one lever by pushing one of the four buttons and moving the lever. I hope that makes sense. All four cylinders would be connected to the multiplier. The other two remotes could be connected to the top-n-tilt cylinders.
6,289
I see.
JasonW
594
363
Al
Added a support brace to the underside of the manifold. Very little flex pulling or pushing on the hoses.
Minor grip with this setup is locking collars on the couplers are hard to push/pull to connect/disconnect. They are spaced close together to keep the block compact but I would see this being an issue with someone older that’s lost dexterity in their hands or such.
