belt twisted
5,417
Go to that Bigiron link, and take 'snapshots' to download the 14 pictures !!! Worth their weight in gold as the ONLY ones I've been able to find....... It is a rear discharge mower so...... I'm thinking all you need is the proper blades on the beastie ( which it might have...).
With engine off(yeah, obvious but safety first !! ), turn PTO shaft CCW and see how the blades turn ( mark on deck....easy to forget...) then see if blades 'cut' grass(spin right way) .
This would be a fun project........getting new blades might be easier than you think.
Speednut
B6000Ecan
Mar 1, 2025
12
Conyers,Ga.
yes, it turns counterclockwise. I have extra belts for it but not extra blades. why do you think it has 2 mowers on it at same time the belly mower is 44 inch it is Kubota also just makes no sense.
7,652
Yea 2 mower does not make sense.
5,417
well it IS a 'finish' mower...... ;)
could be previous owner had health issues. the finish mower does have a wee bit of rust on it and an interesting 'access' hole for one of the pulleys !
