Anyone Ever Installed a 3rd Function Valve Kit?
RLinNH
B2650,LA534,BH77
Mar 10, 2018
79
14
NH
I am considering installing my own 3rd function valve kit on a 2018 B2650. Anyone here ever done this job before? How did it go and did you feel overwhelmed with the job?
I do all my own maintenance on my tractor and vehicles. I'm not a professional mechanic, but a shade tree mechanic. Still, I don't want to bite off more than I can chew.
D.jFarm78
L2250 FEL& L4610FEl, BH, Grapple, Mower, Gannon , blade, disc, plow, rototiller,
Mar 20, 2020
46
17
Young, Az USA
I installed one on my L4610 a few years ago, was not difficult. I got a kit from Summit Hyd.
The only difference was the mounting, since I have a after market cab from Curtis.
They were very helpful on any questions I had during the choosing process and install.
RLinNH
B2650,LA534,BH77
Mar 10, 2018
79
14
NH
I am also looking at the Summit package. After your post, I will be purchasing it in about 5 minutes. Thank you
MOOTS
MX6000
Jun 27, 2019
2,233
2,850
Canton, Georgia
The summit kit is very easily installed on that tractor. @bird dogger has an excellent write up with pictures posted here. I followed it while installing the summit kit on my LX2610.
bird dogger
Feb 24, 2019
1,807
1,782
North Dakota
RLinNH, it's an easy "chew" to install it yourself !! My B2650 install write up that @MOOTS referenced is here
Edit: I had to go back and look at what year I installed mine. April of 2020, almost exactly 5 yrs ago. I haven't had any issues with it during that time.
eipo
L4060
Dec 1, 2015
699
85
MI
I installed the Kubota kit on my 4060. Pretty straight forward.
lynnmor
B2601-1
May 3, 2021
1,821
1,621
Red Lion
I see that you have a backhoe listed, that makes the job a bit more difficult and Summit likely doesn't have all the parts required. Find the instructions first for both the Summit and the one from a Kubota dealer.
I installed a Summit on a B2601 with a BH70 and had to have hoses made and needed some parts. At one time, the genuine Kubota kit was the way to go, I believe things have changed so do your research.
I see there is some information on here: https://www.orangetractortalks.com/...d-function-kit-install-on-kubota-b2650.44616/
RLinNH
B2650,LA534,BH77
Mar 10, 2018
79
14
NH
I gotta ask. How can a 3rd valve function kit on the front end loader affect the backhoe? I was always under the impression that the backhoe is totally independent from the front end loader...
MOOTS
MX6000
Jun 27, 2019
2,233
2,850
Canton, Georgia
It’s in the plumbing. Read bird doggers thread, he has a back hoe. I think he had an extra fitting or two that weren't needed in the summit kit.
bird dogger
Feb 24, 2019
1,807
1,782
North Dakota
Moots is correct. I do have the backhoe plumbed in. In this post Post #5 towards the bottom of the post you'll see the extra hydraulic fitting I welded a small bracket to. That bracket bolted to the side of the tractor and along with its hydraulic coupler....the return line to tank coupled into it when not using the backhoe. With the backhoe installed....that return to tank line was uncoupled from that fabbed up fitting and the backhoe's hydraulics coupled up between them. Very simple and easy to see, once you start installing your kit.
I don't remember if I had to buy that fitting seperately from our local hydraulic shop or if it was in the kit.
It's a low cost item at any rate.
Because my backhoe had already been installed by the dealer.....some of the plumbing requirements needed for the 3rd function install had already been done to accomodate the backhoe.
Also see Post #10 in that same thread for more pics of that mounting bracket and location I used for the backhoe connecion.
biketopia
Feb 15, 2024
437
469
Warrenton VA
I installed the Summit kit on my B2650 two years ago. Has worked flawlessly and very easy to follow directions. They also offer a discount when ordering online if you use the promo code found in their thread over in the marketplace section of the forum.
Having the backhoe already plumbed in should just mean you don't need to remove the factory steel power beyond line. You might need to route your hoses slightly differently but no big deal. Reach out to Summit and they should be able to set you straight if Bird Dogger's thread doesn't cover it.
I added 2 rear remotes last spring with the help of the forum and it was an easy install just moving the position of one line from the 3rd function and getting a 13" hose made up to complete the loop.
je1279
Dec 6, 2020
834
585
Upstate NY
I installed the Kubota 3rd function kit on my LX2610. The most difficult part was installing the new connections in the rear without removing a bunch of parts.
Rickstir
L4701, LA765, RCF2072
Mar 14, 2025
What did ya'll do about the wiring? Summit instructions say go to battery. I don't fill comfortable wiring straight to battery without a fuse/relay in circuit? I searched for a switched circuit under the hood that would be fused but had no luck. Thanks
7,332
Inline fuse holder. Buy pne at your local auto parts if one does not come with the kit.
