Pictures or it didn't happen right?
@biketopia, thanks for emailing all those documents over earlier in the week.
Here's the red beast! I took the photo this morning and I will say that the metallic flake looks better in person. The first owner had the windows tinted, but also had an awful strip added across the top of the windshield. I'll be removing that for sure.
I asked the dealership if they'd "throw in" the Ford 2-5/16" gooseneck trailer hitch kit since the truck is set up with the factory gooseneck prep, but I'm not overly optimistic. I'll most likely order the B&W kit which is nicer anyway, and I'm a B&W fanboy. Another plus is that the conventional receiver on the truck is a 3" variant and I already have a B&W tow and stow 3" hitch that I bought for the M1078. A big appeal of this truck is that other than a gooseneck hitch kit, I don't need to buy anything else.
It's a great-looking truck, an old work buddy has the same color, and pops in the sun! Sure thing on the documents, hopefully, they were/are helpful! If you need anything else, you've got my info. I wouldn't immediately pull the brow off the windshield, drive with it for a bit. I do it to all my cars, it helps with sun glare, especially rising and setting. How they did yours might be a little further down the windshield than I typically go, but might be ok.
Those trucks were built for exactly what you are going to do it with it, tow and tow heavy. Stay up on your maintenance with the 6.7, and use Ford oil and fuel filters and your own flavor of oil. If it has a drain plug on the trans, do a drain and fill with the correct Ford ULV fluid every so often and you should have no transmission issues. Another maintenance point often overlooked is the crankcase filter. I think Ford changed it to more of a screen versus a filter on the early 6.7s. The early ones never got changed and eventually, they pushed the silicone out around the upper oil pan area. Trans has to come out and front cover off to reseal the upper pan. If it seeps, get that covered under warranty.
Last thing, the front valance, we pull those off pretty much all of our super duty's. Either they are removed when we install a plow mount, or they get ripped off in the snow or catch a parking stop. We've seen no issues with removing them however I assume it's there for mileage so maybe there is a slight gain to having it.
