DPF Engine warning flash indicator
BwanaDon
Kubota L3301
Feb 27, 2025
Middleburg Fl
Just purchased a 2019 L3301. 151 hrs. Dash display was dead due to blown 5 amp fuse. When the fuse was replaced I got a solid engine warning light with alarm at 1 second intervals. Trying to follow the steps for idle regen in the manual but instructions are not clear at least to me. Would appreciate any constructive advice.
Manual says park the unit and contact dealer.....
9,867
If you look at the chart below, it sounds like your tractor is at PM warning level 4 so a dealer will need to look at it. Did you buy it with the fuse blown so didn't know about this, or did you buy it and then the fuse blew?
9,604
This line says it all!
It's sounding like you got taken advantage of. 😞
That tractor has to be running like poo. :poop:
That's a stage 4, you can't fix it.
It will require a dealer to do a computer controlled forced regen and even that may not make it work.
You may have to pay to have the DPF / DOC replaced/repaired.
I hope you don't as that's a $4K set of parts.
I'm slow typing, Yea what @McMXi said. ;)
BwanaDon
Kubota L3301
Feb 27, 2025
Middleburg Fl
Thank you for the info
whatsupdoc
L3302
Jul 9, 2024
125
130
I understand that the engine ecm requires the Kubota software
in order to get an attempt to regen,
Would removing the DPF and manually cleaning it help?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
847
762
E.
yup... common trick is to kill the display so buyer can't see error messages, hrs, etc....
sick of seeing so much auction stuff and facebook marketplace stuff that reads "runs like new" until buyer gets it home and finds out it is broken and being dumped on unsuspecting folks.
me I like to buy new and keep forever but realize others might not have the luxery. More so than ever it seems buyers need to be ultra cautious on buying used and taking the sellers word for it.
9,604
Not at stage 4, because the computer locks in the code and keep the motor derated till repaired and reset.
BwanaDon
Kubota L3301
Feb 27, 2025
Middleburg Fl
the tractor ran
The tractor ran fine. No power issues. Just the alarm code. I contacted the local dealer and took it to them today. They hooked it up to their magic computer and did a forced regen. Afterwards cleared out previous codes. Good to go. $330
out the door. I am pleased with the outcome. Thanks for you input
Moose7060
Oct 14, 2023
827
2,243
bc
the tractor ran
Glad to hear it is up and running and wasn't too painful for you.
9,867
The tractor ran fine. No power issues. Just the alarm code. I contacted the local dealer and took it to them today. They hooked it up to their magic computer and did a forced regen. Afterwards cleared out previous codes. Good to go. $330 out the door. I am pleased with the outcome. Thanks for you input
Great to hear that the issue has been resolved and for a reasonable cost, but interesting to read that the tractor ran fine. According to the manual the engine output is limited to 50% when in PM warning level 3 or 4, and clearly you were at level 4.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,691
2,129
Western MT
"Ran fine" was probably hard to tell for a new to him tractor. In any case, it should run fine now. :D
9,867
5,504
2,213
you'd be surprised how many people keep using them with the dpf completely plugged (level 5), and don't knwo that there's any problem. I mean, it's got beeping buzzers, flashing lights, and probably has been doing that for who knows how many hours...and they kept on trucking, er, tractoring, as if nothing was wrong.
Then auctions. People sell stuff at auctions because it's an easy way to dump junk or problematic stuff (yeah, i'll just call it "stuff"...) and never have to deal with the buyer in person. That way the "stuff" can be peddled and ain't nobody to complain to but the auctioneers, and I can guarantee you that they don't care one bit about the "stuff" that they're auctioning off.
